Question about Stihl Ts 510 760 Cut Off Saw Repair Manual
SOURCE: TS 510 av saw. My
There could be a few problems. Check the air filters and make sure that no holes are present in them. Then check to make sure the unit has compression. A general check of the compression for a Stihl unit is to hold the unit up by the rope and it should hold itself up. If it slips down really quick or if it does not hold itself for more than a couple of seconds before the rope starts coming out, then the unit is low on compression and will need a new piston and cylinder.
Also another thing to check is the carburetor. With the new fuel with ethanol/methanol in it, it can damage parts in the carburetor. The sealant that went over the welch plugs will come off and it will flood the unit out because there is no regulation of the fuel going into the engine. You can try putting new sealant, such as clear fingernail polish over them, and see if it holds and will regulate the fuel correctly. If the air filters have holes in them then the low compression could be caused from dirt ingestion and it could have caused wear on the main bearings. You can check for bearing wear by seeing if the flywheel or the clutch will move up and down and sided to side. If this is the case then you will need to purchase a new unit.
Posted on May 10, 2011
SOURCE: stihl ts 350 super cut saw died in the middle of cutting a brick
i am doing one right now (ts350). I had no spark. 2 problems there. I had to replace on/off switch do to dust making it malfunction. still no spark so I had to replace the Ign. module. got great spark now. It's not cheap either ($226.00 canadian) had to order it from a dealer. Now I have no fuel getting to the cylinder so I have more work ahead of me. I hope this helps if you only have a no spark problem. It's about a 6 on the skill level.
Posted on Sep 21, 2012
Aug 13, 2018 | Delta Saws
May 28, 2016 | Stihl Saws
Mar 09, 2015 | Garden
May 04, 2014 | Stihl Chainsaw Cutoff Saw Muffler 050 051...
Jul 12, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
Jun 01, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
Mar 18, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
Aug 05, 2010 | Stihl Ts 510 760 Cut Off Saw Repair...
Sep 06, 2013 | Stihl Ts 510 760 Cut Off Saw Repair...
347 people viewed this question
