Question about Hitachi 43F300 43" Rear Projection Television
We have a hitachi HD tv It keeps shutting off and the blue power light flashes? We have to un plug it and wait sometimes 10 minutes until it works again?
Posted by Gigi on
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
Anonymous
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
Michael Borelli
  • 979 Answers
SOURCE: Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Posted on Feb 15, 2008
Ecollier2012
Edward
  • 3459 Answers
SOURCE: Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 07, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Hitachi 50UX22B projection ultravision. shutting off on its own.
Since the set seems to recover somewhat, Id look for poor sonnections first rather than defective components. If you can solder and arecomfortable working inside the set, you may be able to fix this yourself. Are there any other symptoms other than just shutting down? For example, blinking standby lights?
Dan
Posted on Jan 14, 2009
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
JVC HD-56G887 wont turn on
Your TVneeds to be serviced by a JVC authorized service center.
Mar 17, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Hitachi TV Model 43FDX10B
open it up get dust all out clean it well ok then ya use fans around it vented area to keep it cool its getting to hot dust build up
Jan 28, 2008 | Hitachi 43FDX01B TV
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Sharp aquios 32"
unplug the tv from the power outlet, wait until the light stops flashing then plug it back in. works for me.
the flashing light means that your tv needs to be serviced, if its still under warranty you shouldnt have to pay for this.
-w
Nov 17, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV Problem with shutting off by itself
Mine just did the same thing.  Except for it was green instead of blue.  The service manual states 8 flashes from the light stands for an overvoltage.  After reading the manual for a bit I realized the bottom row of 3 adjuster screws from behind the speaker grill adjust the output for the red, green, and blue colors.  BEFORE OPENING ANY TV OR MONITOR PLEASE KNOW THAT THE VOLTAGE INSIDE CAN KILL YOU EVEN IF UN-PLUGGED so please be careful and only adjust what is mentioned here.  I un-plugged the tv, removed the grill and the board covering the internals, and carefully turned the 3 adjustment screws all the way down.  I then waited about 10 minutes (don't know if this made a difference).  I turned on the tv, turned the channel to an auxilary input (for a black screen), and slowly raised each of the 3 bottom screws one by one up clockwise until i could see a faint green, blue, or red line (depending on the screw), and then turned each one back a hair until the screen was black again.  Only adjust one at a time, the order for colors are blue, green, then red from the left.  I hope this fixes your problems.  Be careful when working inside a tv,  I suggest not using a screw driver to adjust the screws due to the possibility of it slipping and someone getting hurt.
Sep 16, 2007 | Sony KP-51WS500 51" Rear Projection...
Open Questions:
Hitachi 43F300 43" Rear Projection Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
