Question about Furniture
JCP electronic recliner model "The Bed", will not recline, vibrate, heat, nor will light in arm come on. Normally when power modules are plugged in chair activates. One of modules was accidentally damaged and probably needs replacement.
Posted by john jones on
happycouple7
    New Friend:
  • 189 Answers
Replace the modules. have to have service man to replace.
Posted on Sep 03, 2014
3 Related Answers
don dolev
  • 25 Answers
SOURCE: I just bought the VRETA recliner from Ikea and went to put it together only to realize that I seem to have lost the instruction manual. Does anyone know where I can find the manual for this chair?
The Ikea website has copies of assembly instructions for all of their products. I have copied the link to the manual for your requested product here for you.
http://www.ikea.com/assembly_instructions/vreta-recliner__AA-167545-3_pub.PDF
Posted on Aug 09, 2012
norm geist
  • 18 Answers
SOURCE: My husband complains that he cannot sit comfortably on any recliners. He is very tall (over 6 feet) and says that he simply does not fit in the standard recliners. Is there such a thing as a recline
Actually, yes there is. There are some recliners designed for people between 6-6'6" tall. They may be slightly more expensive, but he will definitely fit comfortably.
http://www.lift-chairs-4-less.com/LC4L-LL-575prlllich.htm?utm_source=Shopping&utm_medium=cpc&utm_campaign=Shopping&
nate vank
  • 18 Answers
SOURCE: What exactly is a recliner? How is it different from other chairs?
A recliner is a type of chair that can tilt backward. They usually come with a built in foot rest that comes forward when the user tilts back. They have the ability to adjust from a slight incline to lying almost flat.
What type of power connection do I need for this plug
Norm it is not a simple matter of getting a power connection you will need the correct power supply for your recliner .
This might be the power supply unit you will require
however you need to check if the recliner uses 29 volts DC it may be marked on the recliner . You may need to get someone to help you look closely at your recliner to see if there is a label with its operating power voltage and if it is DC or AC and current ..
https://couchguard.com.au/lift-chair/electric/electric/power-supply.php
May 31, 2016 | Computers & Internet
Motor stopped working on both recliners
Hard to imagine two separate motors going fubar at same time. Sure it is not a power issue? Remote control?
Feb 21, 2016 | Starfire Two Arm Theater Recliner...
Recliner sofa won't recline
Try looking next to your seat cover and the arm rest for a little pull handle. If it is a pushback recline model tried looking to see if the shipping ties are untied underneath. Or try simply pushing back while you're sitting in it with your shoulders.
Mar 18, 2014 | Furniture
Lazy boy recliner with heater an d massage: I
Sorry we do not have any wiring diagrams for this chair here.
Apr 14, 2017 | Coaster 500663 Tri-tone Lazy Boy Style...
How do I tighten down arms?
I know it's late but Barca just sent me special tools that they expect returned. Unfortunately, the screw has completely fallen off into the closed chassis!
Sep 21, 2013 | BARCALOUNGER-RECLINERS Barcalounger Oracle...
Invacare power chair model #1089384; is stuck in the reclining position and won't come back up
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Jan 18, 2011 | Invacare Health & Beauty
I have a 2004 Chevy Silverado. The heated seat on the drivers side does not work. When you push the button to turn it on, the lights come on briefly then turn off.
Would you say it stays on about 30 seconds and does the passenger side do the same thing? If possible retrieving the codes will narrow down the search for a correct solution.If the passenger side is ok we may be able to eliminate the passenger side as bring part of the problem.Please advise so will know which way to go with your solution.
Condition/Concern:
Driver and passenger heated seats inoperative or shut off in 30 seconds. There will be DTCs B2435, B2440, B3606 and/or B1825 set in the Drivers Seat Module. The adjustable pedal position sensor, seat recliner position sensor and both heat seat thermistors share the same 5 volt reference internal to the Drivers Seat Module. A fault in any of these components/circuits can make the heated seats inoperative or shut off in 30 seconds, as well as, the seat recliner and/or adjustment pedals may move in short increments when operated. A fault in heated seats, adjustable pedal or seat recliner will affect BOTH heated seats.
Note:: Even if the vehicle is not equipped with adjustable pedals DTC B3606 still may set.
To help isolate the area of concern use the Tech 2 or a comparable scanner and go to "Sensor Data" in the Drivers Seat Module. Monitor the following parameters for being out of range:
Recline Position- Normal range .39V-4.58V
Pedal Position (if equipped) - Normal range .39V-4.58V
Psgr. Seat Heat Sensor- Normal range 1V-4V
Drvr. Seat Heat Sensor- Normal range 1V-4V
If a parameter is found to be out of range inspect circuits for any opens, shorts to ground, or voltage. If none found replace the suspect component.
Please be aware of the following common areas of concern:
  1. The adjustable pedal position sensor internally shorted pulling the 5 volt reference low. Disconnect the adjustable pedal position sensor and see if the heated seats start working correctly, if so replace. Note Important:: The APP (Accelerator Pedal Position) sensor is NOT the adjustable pedal position sensor. Make sure the correct sensor, adjustable pedal position sensor, is disconnected.
  2. The seat recliner position sensor internally shorted pulling the 5 volt reference low. Disconnect the recliner position sensor and see if heated seats start working correctly, if so replace.
  3. An open in either heated seat thermistor circuits (signal or low reference). The most common is the passenger thermistor where it passes through seat connector C305 pin "L" or "K" or C399 pins "R" or "G".
  4. A chaff to ground on either heated seat thermistor signal circuits. The most common is circuit 5475 black/red or dark blue shorted to ground in the passenger seat near the buckle. Note Important:: The heated seat thermistors act differently to "OPENS and SHORTS" than the adjustable pedal position sensor and seat recliner position sensor. The adjustable pedals and seat recliner sensors can be disconnected for testing of the heated seats. Where as the heated seat thermistor circuit must be working correctly before EITHER heated seat will operate. Disconnecting one thermistor, which may have a concern will not allow the opposite heated seat to work correctly, BOTH side must be operational before EITHER heated seat will operate.
Clearing DTCs
If DTCs will not clear when using the Tech 2 or comaparable scanner after a repair has been made, try operating the device in which the repair was made. Example, if a repair was made to the passenger heated seat thermistor circuit, the DTCs may not clear unless the passenger heated seat is operated.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Nov 17, 2010 | 2004 Chevrolet Silverado 2500HD
Furniture Logo
402 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
