SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
SOURCE: Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
SOURCE: My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Testimonial: "Very helpful. We had a small kitchen fire that put out a lot of smoke, so that was probably the problem"
SOURCE: Philips PET710 DVD player shows 'no disc' when disc inserted
The safest way , this may sound really stupid but has always worked for me is give it a slightly rough slam on its bottom and it will work , dont judge this badly for it actually wotrks
