The logiq 400CL(Proseries) does not come on-the digital printer powers for a second and then off, the monitor only gives a speaker sound and doesn't light up, the keyboard doesnt light up, the floppy doesnt come on. What are the possible faults?
Your ultrasound machine has a problem communicating with a hard drive or another device on the SCSI bus. If it uses SCSI as an interface, then it is a pretty old piece of equipment Recommend you refer this to a qualified technician.
possible system needs to be setup for the alteration on power . try entering on pc the specs and name in search box. you might be pleasantly surprised with. information web site .
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Symptom : No images on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power cord connecte properly.
Checklist 2 : Can you see "Check Signal Cable" on the screen ?
Action : (Connected using the D-sub cable)
Checklist 3 : If the power is on, reboot the computer to see the initial screen (login screen), which can be seen.
Action : If the initial screen( the login screen) appears, boot the computer in the applicable mode (the safe mode for Windows ME/XP?2000) and then change the frequency of the video card.
Note : If the initial screen does not appear, contact the Service Center or your dealer.
Checklist 4 : Can you see "Not OPtimum Mode", "Recommended Mode 1440 X 900 60 Hz" on the screen.
Action : You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
Adjust the maximum resolution and frequency that the monitor can handle properly.
Checklist 5 : There is no image on the screen. Is the power indicator on the monitor blinking at 1 second intervals ?
Action : The monitor is in Powersafe mode.
Press a key on the keyboard activate the monitor and restore the image on the screen.
If there is still no image on the screen, press the On button. Then press any key on the keyboard again to activate the monitor and restore the image on the screen.
