SOURCE: Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
SOURCE: Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
SOURCE: preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
