SOURCE: Dryer won't start; all lights on; minutes just blink
well you may have a couple things wrong with your unit first check the door switch to see if its making contact telling the unit it's closed, if it doesn't read a closed circuit when pressed replace the switch if it does replace the main control board. If you are getting any fault codes you can remove the lower panel on the dryer ( 3 screws at the bottom ) and check the tech manual on what it is ( if someone did not take it ) hope this helps good luck.
