Watches Logo
Question about Watches
Northwest 72-MA878 Bluetooth watch directions. Watch was in 12 hour time, recharged and now on 24 hour time. howdo i get it backto 12 hour time? thak you.
Zee Zee
    New Friend:
One of the answers on this page said at the end that "You may have to use pliers to turn the knob" NEVER, EVER USE PLIERS ON A WATCH CROWN (Knob) If you absolutely have to, use a piece of leather or rubber to grab it with if your fingers are too weak to turn it, but NEVER Pliers! Using pliers is idiotic! That is of course, unless you don't mind ruining your watch and scratching it all up.
Posted on Mar 04, 2016
5 Related Answers
Anonymous
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
Anonymous
SOURCE: how do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Posted on Nov 10, 2007
Barbara Phillips
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
Anonymous
SOURCE: How do I change my Casio twin sensor alti thermo
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Posted on Feb 21, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: E010 S95986 HSB power cell does not hold charge
Change the capacitor. This is the thing accumulating the energy. As the ordinary batteries, it may go bust, so, all you have to do is to replace it. There is no such a name as power cell in Citizen EcoDrive watches - there are CAPACITOR. Capacitor absorbs the energy from the light sensitive panel(s) and dispenses it in the ordinary battery manner. Advertisements are saying that you will never have to change the battery - that's right, because there are no batteries at all. Instead of battery there are CAPACITOR, but nobody says it will last forever. Rate me, plz.
Posted on Mar 05, 2010
Testimonial: "Thanks, that's what I expected. The manual says the watch has a manganese titanium rechargeable battery--I will get it checked."
How to set for 24 hrs.
Dec 29, 2015 • Watches
1helpful
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
1helpful
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • 0helpful
    Timex 1440 time from 24 hour clock to 12 hour
    Hi bowingman,
    To use 12- or 24-hour time for your watch, please follow the instructions below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    1helpful
    The date changes at 12 in the evening
    The watch is set-up for a 24 hour cycle. It sounds like your watch is 12 hours late, so if you just advance the time 12 hours ahead, everything should be solved.
    How do I set watch as a 24 hour mode clock ?
    With TIME displayed, press and hold ADJUST, then press MODE to switch between 12- and
    24-hour format.
    9helpful
    2answers
    Aquatech watch
    press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
    press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
    hope this helps
    jeff
    Jul 23, 2008 • Watches
    13helpful
    4answers
    Military Time
    Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
    Chris
    27helpful
    3answers
    Timex Indiglo WR 30M
    NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
    FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
    WATCH IS SET TO 24-HOUR TIME.
    4helpful
    24 hour-12 hour time
    Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
    Top Watches Experts
    Marvin
    Marvin
    john h
    Are you a Watch Expert? Answer questions, earn points and help others
