Video Game Consoles & Games Logo
jennifer laspada Posted on Sep 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i find the ssid on the wii - Wii Nintendo Video Game Consoles & Games
Brian Sullivan
Level 3:
  • Master 27,725 Answers
  • Posted on Sep 21, 2013
Brian Sullivan
Master
Level 3:
Answers
27725
Questions
Helped
5664389
Points
79191
You have set up your Wii and are anxious to begin playing games.
But when testing your Wi-Fi connection to your Wii, you are receiving errors.
The error is "Your wireless network is not within range or incompatible to the Wii" What should you do?
One of your first steps is to check your SSID. An SSID, or service set identifier, is a 32-character code that specifies the access point of your wireless network.
The SSID also acts as the name of your wireless network.
This ID is defined on your network's router software.
The SSID for your Wi-Fi network and the Wii settings must be in sync for the Wii to function properly.
Go to your computer and log in to your Internet router settings.
Find the wireless settings information for your router.
Locate the SSID field. This field displays the name of your wireless network.
Carefully write the SSID on a piece of paper.
Make sure that you are copying the SSID exactly as displayed in the SSID field.
Pay attention to capital letters, spaces or special characters.
Go to your Wii.
On the Wii main menu, click on the "Wii" button in the lower left corner.
The Wii Settings screen is displayed.
Click on the "Wii Settings" icon on the right side of the screen.
Click on the blue arrow on the right side of the screen to move to page 2 of the Wii Settings options.
Scroll down and click on the "Internet" button.
Click on "Connection Settings."
Click on your wireless connection.
Click on "Manual Setup."
Click the blue arrow to find the SSID field.
Carefully compare the SSID entered in the Wii's SSID Settings field to the SSID that you wrote down from your router settings.
If these SSIDs are not identical, change the Wii SSID to match your network's SSID.
If the SSIDs match, the SSID is not the problem with your Wii setup.
Contact Nintendo Technical Support for additional troubleshooting information.
http://www.nintendo.com/wii
Wii official site at nintendo
My wii is giving me an error message of 51030
Error Code 51030, 51031, 51032 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
2answers
Keeps saying error code 051031
Assuming you are referring to the Wii console, this is suggested troubleshooting:
Hit the link below for access to the posted troubleshoots listed
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Error Code: 051031
  • Check for interference that may be preventing a successful connection. Click here for tips.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufacturer's website; consult the manufacturer for more information.
  • If the problem persists, try our general troubleshooting steps.
Trying to connect netflix and getting error message 51030
1helpful
I dont know my ssid for my wii
the wii does not have an SSID
An SSID is the name of your wireless network that you are trying to connect to
I have inserted my Netflix Watch Instantly DVD into the WII and I have wireless internet service at home, the console asked me to enter the SSID number so I figured this was my wireless network password...
The SSID(network name) is actually the name you give the router. When you are on a wireless device and look at available wireless routers in range, the name you see is the SSID. You can see the SSID in multiple ways,
Login to your router admin page by going to the router ip address(usually 192.168.1.1) and log in. After you log in, go to the wireless settings and confirm your SSID.
If you have a wireless device like a laptop, you can view all available wireless routers in range and you should see yours show up. Check what the name of it is(SSID) and use that and input it into your Wii.
For additional help, read my tech article on how to connect your Wii to the internet. Click here to read it.
Regards,
-G33k
2helpful
Where do you find the ssid code to connect to the enternet with the wii
You will need the SSID and the network key/password (if you have one set up). The SSID is on the wireless router and is the network name. You may need the password also to access the net on the Wii.
Regards.
1helpful
What is SSID number for my will
Your WII will not have an SSID. The SSID will from your router, it is the name of the wireless network you connect to on your computer.If security is enable on your router you will need that same password when you try to connect your WII to your network.
How do i get the ssid code or how do i hook my wii up 4 a wireless internet
the SSID is the name of your router and most of the time the wep key you need is marked under the router, the first thing is to search for the SSID( your routers name) on your nintendo wii, when you have found the right SSID witch by the way should be the strongest signal around as it should be the nearest signal, then you need to put in the wep key ( the same wep key you have on your pc,) that is if you have secured wireless signal, if you have an open signal you should be able to search for the SSID, and when you found the right SSID you just need to connect.
Hope it helps!!
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
