Your System may be slow due to following reason
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
What kind of pc do you have ???
SOURCE: 1gb pc2700 333mhz ddr wont work
You may have just bought a stick of gum! This ram could have been sold on e-bay for any number of reasons. It's not likely that you can get your money back. Sometimes even identical appearing ram won't function with original ram. Check with tigerdirect.com on the web for ram and other computer parts. Good luck!
Testimonial: "yeah i thought so, stupid ebay robbers. thank you very much."
SOURCE: Installed 2 GB of Ram
One of the RAM modules may be bad. Try each one individually to see if that is the case.
SOURCE: I have a HP a1514n
First of all, make sure you have the right memory - 240 pin, DDR2 SDRAM, PC2-4200 MB/sec.
Your machine should support the memory as it has two banks of 1. Sometimes it is simply a sequence problem. In older machines with mixed memory, I always put the largest and fastest in the first slot. You might try just reversing the memory.
