Thermador PSC364GDZS Gas Cooktop Logo
max tarrab Posted on Sep 21, 2013
I have error f19 on my thermador double oven i cut the power for two hours and it didnt help, any assistance would be greatly appreciated!
Thermador induction cooktop CIT304E error code U 24
Question moved form Water Heaters to Thermador Cooktop
There is an F24, but not a U24
F24 Touch input key stuck Replace power relay board, and touch panel
https://www.google.com/search?q=Thermador+induction+cooktop+error+code+U+24
1helpful
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
1helpful
Where are the inline fuses on the Electrolux Frigidaire double ovens?
I appreciate your post, Richard Balzer!
I see that you would like to know the location of your inline fuses on your Electrolux wall oven. I have located the wiring diagram and the parts manual for your wall oven. I do not see the location of an inline fuse. I hope this is helpful information. -Matt
Frigidaire Manual Search Results
Error code 32
Same unit, error 32. Replaced capacitors that were bulging on relay board. Work for a bit now same error message. Read somewhere else that they capacitors on filter board likely went as well. Where is the filter board located? I am guessing under the induction elements because I can't imagine it would be anywhere else. Can someone please assist in telling me how to access that board? I would greatly appreciate it
Hello, Looking for the oven control knob for Thermadore oven model no.CT130 alos mil;ssing small oven panel knob. Can you please help me ?
Sorry to read about your problem, I hope this helps you out.
call this number for knobs 1-877-477-7278
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
The oven was on at 350 degrees. All of a sudden the oven increased the temperature and displayed ER F2 error on the display. What was in the overn was instantly burnt.
If you have a Kenmore or Dacor, Thermador, Amana Caloric, Westinghouse, Admirals, or if you have some retagged oven from this brands, F2 is temperature runaway, usually a bad temperature probe.
On Admirals you may need to test the relay board.
Try disconnecting power (trip circuit breaker or disconnect power cord).
If the error is still there, test if the probe has continuity, then eventually replace it.
On Whirlpool ovens F2 is a faulty keypad assembly.
To get a technician to do the repair call the support number listed on the manual.
Dec 15, 2009 • Cooktops
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
4helpful
2answers
Part 415191 Connection Tail Membrane
We are having the exact same problem with this part! Our oven is a S301T, but it still has the same part number for the tail membrane (touch control).
In FINALLY contacting someone at Thermador we were able to find the following information which might aid you. The part is manufactured by Bosch and according to Appliance Pros.com, the numbers:
Part Number 415191 Manufacturer's number (Bosch) Part number AP2832583 which replaces the part number originally numbered 14-38-680.
Don't know if this will help....it hasn't helped me so far. Thermador suggested that we go to a site named OBSOLETEAPPLIANCEPARTS.com. This site seems to be really messed up because you have to call and leave a message as the site is under construction!
I'm so darn frustrated that I'll never buy a Thermador product again (even thought they are great when they work) Good luck!!
Thermador SGS304 Ignitor does not spark
Hey Frust1
check that the particular burner is properly "grounded" see that no "dirt" is between burner and frame. Also ensure that the insulation on the wire from the igniter unit to the probe at the burner is not damaged.
Regards
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
