Question about LG Escape 4G Android Phone AT&T
Stuck on a download mode screen and says security error
Posted by Ryan on
nelson cruz
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 59 Answers
Press cancel and repeat procedure
Posted on Sep 21, 2013
Iphone stuck on itunes recovery mode
Your device stucks in DFU mode, you can try some 3rd party ios data recovery tool to exit recovery mode. Follow this guide to have a try DFU Mode How to Enter and Exit DFU Mode of Your iOS Device
Aug 12, 2014 | Apple iPhone 3G
Reformat issue blue screen
Bluescreen can be caused by a number of things Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cylce Make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets some motherboards cmos batteries are soldered in might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating Could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory If you get your computer running to get a screen or even do it in safe mode Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select the safe mode option You might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be running select end now and users you will see who is using your computer
you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Jan 30, 2013 | Lenovo Ideapad Z370 10252eu 13.3" Led...
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
My acer travelmate 6292 suddenly hang and when i reboot it blank screen appeared
test all power and data leads that attach to your hard drive the leads from your
(motherboard to your hard drive) Sata make sure they have dust free secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as a faulty fan lead can cause you problems a computer needs all of the power and data to travel through every working device and to
have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
then try it if it does not work
try in safe mode
you might need to get rid of the virus first
or try safe safe mode to download or run your antivirus software
or even safe with a system restore
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Return to OS Choices MenuSelect safe mode with networking to download
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
your operating system must be registered and activated
http://windows.microsoft.com/en-US/windows/products/security-essentials?WT.mc_id=MSCOM_EN_US_DLC_FAMILIES_131Z4ENUS21979
Anti-virus and anti-spyware solution Xp
Anti-virus and anti-spyware solution windows 7 64 bit
you could download and run just the Anti malware program or any other you might need
after you have run the Anti malware program
hope this helps
Aug 04, 2012 | Acer TravelMate 6292 Series Laptop Charger...
Black screen with only a curser
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
after you have run the Anti malware program you should do the safe mode option again and use the command prompt option
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer
hope this helps
Aug 02, 2012 | Computers & Internet
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Jul 16, 2012 | Apple iPad Tablets & eReaders
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
My dell lap top is stuck in an endless round of startup repair and fails to complete booting to windows Vista.I can get to safe mode and safe mode networking but can't find a way to fix the problem.
Unfortunately there are many different causes for blue screen errors, so there are quite a few possibilities to fix it. Try the steps in this article to analyze the cause and fix it.
http://www.pcauthorities.com/pc-errors/how-to-repair-blue-screen-errors
Jun 25, 2010 | Dell Studio 1537 Laptop
My phone Samsung GT-S8003 is stuck on Download mode - GT-S8003
i have todat repair my smsung gts8003, i have relpaced main and sub pcbs, lacd and touch screen now it is howing download mode gt-s8003, what is the solution for this
Oct 18, 2009 | Samsung BlackJack II Smartphone
LG Escape 4G Android Phone AT&T Logo
75 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
