Most likely capacitors failing on the camera process board. They can also cause no picture, dark picture and sync loss. I use freeze spray to try to make the symptoms happen and heat to bring try to isolate it to an area. It's not so easy to change the capacitors if you do find which one (s) though.
SOURCE: GE JVM1630BJ Microwave went completely dead with no power
Sounds like the bulb shorted, which is very common, and the first time it blew the fuse.
It sounds like when you put the new fuse in and tried it again, the bulb was still shorted, and this time it damaged the board.
We see (and repair) thisa lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about aweek.
Atour Web site, we have a videoavailable showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure oftenoccurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often alsoaffect the exhaust fan operation, too. The lights and fan can beinoperable or stuck on too.
Details of our serviceand critical safety information and disassembly information is at oursite, and our link is at ourlisting hereon FixYa.
Feel free to contact me directly (and please remind me of yourfull model number) for more information & help.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
SOURCE: chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
SOURCE: GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
