SOURCE: transmission slipping
What you need is a "revolution sensor" I had the same exact problem. Replaced the sensor and everything is fine
SOURCE: 2003 Nissan Altima 2.5S, Check Engine Light Problem.
this problem could be caused by the mass air flow censor, i had the same problem with my car. it is really pricey at the dealer so you might want to check elsewhere for this part. I found one at a scrap yard for 85% less that the dealer and i also got life time warranty, the dealer does not offer any warranty on this part.
SOURCE: 98 altima oil light on and off oil level fine car restarted and
If oil pressure is LOW this vehicle has a safety feature that will prevent vehicle from starting.(check oil level before you start) Now what I wan't you to do is to have the oil pressure switch checked or changed. This may be the reason why this vehicle is not starting or it can also be that the actual oil pressure is low. To check the oil pressure of the vehicle you will need an oil pressure guage. Remove the oil pressure switch and connect guage to oil pressure hole and check oil pressure while cranking vehicle.Some pressure testers can be connected to oil filter housing either is fine. If this vehicle has low oil pressure the reasons for that are bad oil pump, clogged oil pump pick up(from lack of oil change/poor mantainence) or bad connecting rod and main bearings but this usually have a warning from before (the engine will sound loud by knocking /clicking-tapping noise) It this was happening you may need to rebuild this engine or replace it. Good luck and Thanks for using FIX YA
