Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Hot engine alarm on my 1998 115 hp mercury outboard as soon as you turn the key on the alarm comes on and does not stop until you turn the key off ?
Posted by rickeymckay9 on
rilaxson
    Sergeant:
  • 456 Answers
Alarm is also for low oil but cold be faulty relay unit for alarm.connect heat sender wire straight to alarm and just make sure you always have oil in autolube
Posted on May 13, 2014
1 Related Answer
Anonymous
  • 57 Answers
SOURCE: Hi,I am looking for an online manual for an 85 hp mercury outboar
i have service manual for MERCURY IN LINE 75-150 HP-it covers all however my scanner printer down at present so unable to scan to lappy to be able to email at prez-hopefully this week-waiting on my computer man!
Posted on Oct 15, 2009
2006 mercury outboard opti max 200 engine alarm, (4 beeps). oil was run low, do i need to prime the system or should it prime itself?
The low oil sensor is not "seeing" the oil in the tank...(mine does this when I crank it,, the low oil light stays on).. It uses plenty of oil,,I quit worrying..- -don't feel like taking the oil system apart..
Get one of these.. I have one for every outboard I ever owned..they DO come in handy...
Mercury Outboard Manuals by Seloc 1965 2014
Jul 31, 2017 | Mercury Cars & Trucks
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
The alarm is the overheat horn. It means that your motor isn't pumping water from the bottom of the leg and through the engine cooling ports. You will see water shooting out the side of the motor when it starts getting hot, and if you're not seeing the water shoot out and the horn is on then chances are the pump impeller on the leg is shot. You should never start a boat motor (outboard or any other type of boat motor) without having it sitting in the water or with a water calliper with a garden hose attached on the lower inlets of the leg. If you run it without water you will melt the rubber impeller and damage the engine if it's run too long without water cooling. Take it in to a qualified tech to replace the impeller.
May 25, 2014 | Boating
Smoke coming out of bottom carb on mercury 50hp outboard engine
It's possible that a little fuel vapour come out of a carb on an hot engine that has just stopped.
Does the motor starts again and runs well in higher rpm ranges? Is the stall only when idling? If so, enrich the idle fuel mix ( screw out the idle mix screws half a turn t a time )
Aug 06, 2017 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
393 people viewed this question
Top Light Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
jws1013
Are you a Light Boating Expert? Answer questions, earn points and help others
