SOURCE: sc-ht500 system cable
You cannot wire this system separately, since it is very difficult to separate the power cables from the others which carry the audio parts.if in any case , lets suppose, you could wire the dvd player separetely, you will have no audio since all the audio frequencies are transfered in this cable to the sub woofer and from there to the satellite speakers.
It would be useless to wire it even if we could as there would never be any audio, only video, no matter what disc you use as the only way the audio is comming is throught this system cable to the subwoofer. Actually its the worst idea to implement in a home cinema system, but well, this is old panasonic.. :)
SOURCE: Its possible connect a 5.1 sound pc card to Panasonic SC-HT500 hearing the 6 separate channels?
I am afraid the answer is no - this particular Panasonic will only play full surround when watching DVDs. It does not have the right inputs to grab more than stereo sound from your computer.
-Tha Mp3 Doctor
SOURCE: How to connect pc to Panasonic SC-HT730 home theater system?
From what I can tell from your manual, you do not have auxiliary audio inputs on your system. You can, however, use the TV audio input for sound from your laptop. You will need to purchase an adapter cable that goes from male 1/8" stereo mini plug on one end (your computer jack) to a split (Y) male rca type jack (two connectors for R&L inputs on system. Then you'll need some length of 1/8" male to female miniplug extension cable. You can use the miniplug speaker jack on your laptop as an output.
Of course, if you're using the TV audio inputs, and don't want to unplug them to plug your laptop in, you'll need another pair of splitter cables for those rca jacks on your system so you can plug two different pairs of input devices into them, but I'd try to avoid this scenario if possible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: Panasonic SC-HT75 won't read and play DVD Movies and play CDs
you may clean the lens, then try to play dvd's again.
SOURCE: iI have panasonic home theater SC-PTX7, it
Go to the website and enter the model # for Help.http://www2.panasonic.com/consumer-electronics/support/ Good Luck
"Use only supplied speakers
Using other speakers can damage the unit and sound quality will be negatively affected."
I'd take that to mean you really don't want to redeploy the speakers to other electronics either. Theater in a Box is designed as a package. That proprietary cable connector is a huge clue and disincentive to attaching it to other electronics.
