Question about Samsung HLR5667W 56" Rear Projection HDTV
When turned off the tv makes a whining sound (not the expected whining noise) and then sounds like a wheel (like on Wheel of Fortune) slowly winding down. Yesterday it didn't come on (sound, no picture) so I shut it off and unplugged it, put the plug back in, turned it on and it came back on. Any ideas?
Posted by revjim on
selassie
    New Friend:
  • 41 Answers
The whining if it sounds like a mosquito type whine! it can be a capacitor, i have same issue, you can usually hear when u are on standby but if your hearing like a "wheel of fortune"! and slowing down would likely indicate it's a fan which is possibly covered in dust and the whining is the fan stopped trying to power forward or it slowly moving and slowing down. If you think it's the fan you should unplug your TV to avoid the fan burning out then have someone who knows what their doing take a look at than fan for you and clean the dust away from it, you may be able to get some access through vents in the side and can try your vacuum cleaner in those vents while TV is unplugged but i'd not go messing inside a TV without wearing some rubber gloves!
Looks like the engineer would need to remove TV casing, check fan to see if it is blocked with dust or not, or if just failing for other reason then either clean or replace. If you don't get it done and the fan fails to cool the TV your risking other vital components overheating and breaking for good so best get it looked at, sounds like the fan to me...
Posted on Nov 23, 2013
3 Related Answers
Anonymous
  • 375 Answers
SOURCE: Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Posted on Sep 13, 2007
Nick DelRegno
  • 49 Answers
SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Posted on Jan 24, 2009
nicknovikov
Nick Novikov
  • 101 Answers
SOURCE: I have a Samsung 43in DLP TV. Stays on for 5
check power board for looseconnections.
Posted on Jul 09, 2009
Whining noise that stops when you turn the wheel on a 01 chevy prizm
Add some power steering fluid problem solved if not replace power steering pump problem solved.
Apr 18, 2014 | 2001 Chevrolet Prizm
Very loud whining nose on front end ..
if it is a wheel bearing it should make more noise turning one way or the other,if it doesn't make a difference which way you turn it's not the wheel bearing
Jan 29, 2014 | 2004 Dodge Ram 1500
Whining noise
your color wheel is going out. order a new one and come back to me I will walk you through the process of replacing it
Nov 27, 2013 | Mitsubishi WD-57734 57" HDTV
Clinging winding in steering power steering goes out every now and then could this be a wheel bearing if so can i see a diagram of that
Sounds like your power steering pump is slowly going out. Eventually it will go out all together and you wont have any power steering.
The wheel bearing shouldn't have anything to do with the steering.
If you feel your wheel bearing is shot too, jack up the car, support on a jack stand, and spin the wheel by hand. Listen for any unnormal sound. Grinding, whining, etc.
Jul 01, 2011 | Buick Century Cars & Trucks
When I turn on my Samsung 46" DLP, I get this whining noise that sounds like a soft siren winding up. It cycles on and off with no picture, and then shuts itself off after a few cycles. Sound only.
The tv have a colors wheel is design in it.The whinning noises is it the causes by a dying colors wheel it is spinning off of it motor axis.The colors wheel is dead,require replacing.The colors wheel sit way back of the tv.Have to take out many mechanical parts out before can even come to the colors wheel itself to replace it.If u have no mechanical skills don't tries to replaced the colors wheel by ur self.Hire a tv Tech to do the job,if u don't u do a wrong installation of the new colors wheel in ur tv u will regret it,because the colors wheel functions,link to the tv Light Engine Block itself most exspensive part of the tv beside the CRT-tv tube.
Apr 20, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Front end noise when turning. almost sounds like
There are a couple of things to cause metallic sounds when turning. First thing, is if it's a clicking sound when you turn, then you have a cv joint going bad. It's usually more prominent when moving in reverse, however it can happen just as well while moving forewards. Secondly, if it's more of a grinding or scraping noise, we have a couple of options. The sound could be coming from the brakes, if they're worn or have grit stuck in them, or it could be bad bearings in the front wheel hub. The wheel hub has a tendency to making a whining noise when driving; usually most easily heard when driving past buildings. They can also allow the tire/wheel to present the appearance of leaning when looking at it. If bad enough, it can even rub on the brake caliper, or cause the disc brake rotor to wear out the brake pads prematurely. So, to recap: Check:
CV joints, if a clicking sound brakes or wheel hub bearings if grinding or whining sound.
Oct 19, 2009 | 2000 Jeep Cherokee
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
michtech
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
Failure to start, period.
the whining you hear is most likely the color wheel
it need to reach a curtain rpm before the lamp will kick on
i will almost gurentee one of the colors is broken on the wheel
Mar 12, 2008 | Samsung HL-R5078W 50" HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
137 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
