Question about Krups Dolce Gusto KP 2100 Espresso Machine
Red light flashing does not turn to green on dolce
Red light flashing does not turn to green on dolce gusto piccolo
Posted by Karl Toth on
Uros
    New Friend:
Same thing just happened to my Dolce Gusto Piccolo. It was off for 2-3 weeks, and after turning on, the light just kept blinking red forever. I tried pulling out water reservoir and putting it back repeatedly for a few dozen times (saw somewhere that air should be pumped out of the system), but It didn't help. Then I plugged out the power cord from the wall socket (while the machine was on), and plugged it back after a few seconds. Turned the Piccolo on, and it worked (blinked red shortly and turned green). Maybe it has something to do with induced current. And maybe pulling the water reservoir actually helped :)
Posted on Jun 14, 2014
Stacey Brady
    New Friend:
As already suggested, unplugged machine while flashing and plugged it back in. Works brilliantly again now. my son makes hot chocolates, so was gonna start effin an jeffin at him (its only 2months old) but he hasn't used it 4 a few wks, so top tip 2 the man who suggested that 1 x
Posted on Feb 21, 2015
Zerubbabel Bar-Umoren
    New Friend:
Mines broke down same steady amber light, did my head in for a while, then switched it on holding the on button for awhile till the green light came on, keep holding it turns to a blinking amber, switched it off and back on again...voila steady green lights enjoy my cuppa...cheers
Posted on Feb 24, 2017
Rta Buzo
    New Friend:
Omg thank you so much! Was very sad this morning when I was left with no Chai tea latte... this helped!
Posted on Nov 08, 2016
Moira Scoon
    New Friend:
Hi my dolce gusto pucallpa machine has stopped working, the motor still makes a noise but no water comes through so I can't rescale. I've use daily the pin to clean the needle nothing makes a difference even tried pumping out any sir bubbles. The machine was only used a few times then put away in a cupboard for a couple of years so it's like new!
Posted on Jul 30, 2017
S Harris
    New Friend:
Thanks tip of turning off while red light flashing worked a treat
Posted on Apr 04, 2015
Kari Piltonen
Thanks a lot for a tip. I almost throwed away my coffee maker, but luckily I decided to do google search and found this site. Once again, thanks a lot!!
Posted on Sep 22, 2020
Hanri Van Schalkwyk
    New Friend:
When we turn on the Dolce Gusto the green blinking light turns to a red steady light. What dos that mean?
Posted on Dec 30, 2018
  • Lorraine Gardner
    Lorraine Gardner Feb 11, 2019
    Mine does this too...help!!!
Dinesh Chhetri
    New Friend:
I tried all the methods but the red light is still blinking very fast. As I am in china it is very difficult to find any repair store and even you get its very difficult to communicate. Can anyone help me here. Thank you.
Posted on Mar 05, 2018
  • Eddy Alamsjah
    Eddy Alamsjah Mar 06, 2019
    Mine did the same thing, have to sent it for repairs, but it came back again with a fault after 3 months.. Factoring the lifespan of the machine and a few boxes of unused capsules, it is more costly owning this machine than getting a fresh brew from starbucks.
Allison Ward-Seidel
    New Friend:
Thank you so much!!! Your trick worked for my dolce gusto mini-me machine too!
Posted on Jun 29, 2016
3 Related Answers
jean
SOURCE: dolce gusto kp2100 won't stay on
in the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
Posted on Nov 05, 2012
rafareynoso
SOURCE: Dolce gusto red light goes out green light does not come on
Hi, my mom's dolce gusto did something similar. I took a look at it closely at every possible part not working and found the power button stucked in pushed position. I could have sent it to a service center but in Mexico that will take for ever and could be more expensive than buying a new one. So i jussy
Posted on Sep 15, 2012
Anonymous
SOURCE: i have a Nescafe Dolce Gusto coffee maker and when
Hi Ron, my name is Katelyn, and I help with the marketing for Dolce Gusto. There is a live chat2_bing.gif with a specialist on our Web site (http://www.dolce-gusto.us/Public/Contact-Us.aspx) or feel free to call the consumer services at 800-745-3391.
Posted on Feb 09, 2010
My light when on its a yellowy colour it used to light green
KINDLY DO DESCALING BUT IF YOU DO YOU HAVE PRESS THE POWER BOTTOM FOR 5 SECONDS AND IT WILL BLINK YELLOW OR ORENGE ONLY THEN YOU CAN DO DESCALEING THE LIGHT WILL GO BACK TO GREEN BUT ONLY AFTER DESCALING
Apr 06, 2015 | De'Longhi EDG200T Nescafe Dolce Gusto...
Dolce gusto light turns yellow more orange. What is going on?
To solve you oregne light problem you must do this press power bottom for few seconds to make it flashing Orange this means that the machine is now in descaleing mode then do the descaleing product be sure you use dolce gusto descaleing only after you done reset power bottom this should solve the problem.that was a working for descaleing
Mar 27, 2015 | De'Longhi EDG200T Nescafe Dolce Gusto...
Why does my flashing red light turn to orange and not green
HI THIS IS BECOUES YOU ARE DUE TO DO DESCALE .DO DESCALE ONLY WHEN YOU PRESS THE POWER BOTTOM FOR 5 SECONDS TO GET THE MACHIEN INTO DESCALING MODE .SEE THAT YOU GET DESCALING FOR DOLCE GUSTO ONLY IN SIDE YOU HAVE AL THE HALPE YOU NEED
Green light will not come on. red light continues flashing
I have experience in Dolce Gusto melody 3. I think that means that the machine warms up the heater. If it continues giving red flasher, i expect that no electricity reaches to the heater or there is something wrong with the heater sensor. In my machine there is Triac (BTB08-600CW) that drives the heater. Please check and show us what is happen.
Dec 30, 2013 | De'Longhi EDG200T Nescafe Dolce Gusto...
Dolce gusto kp2100 won't stay on
Oct 07, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Dolce gusto problem
In my case problem was dry/old electrolitic capacitor.
Label on PCB - C2
Value 470u/10V 105 degC
Sep 23, 2012 | Krups Nescafe Dolce Gusto
Jan 19, 2012 | Coffee Makers & Espresso Machines
Krups Dolce Gusto KP 2100 Espresso Machine Logo
27,117 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
