Onkyo TARW255 Single Dual Cassette Deck Logo
Question about Onkyo TARW255 Single Dual Cassette Deck
Cassette Recorder play problem
Cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and FFWD stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away.
Posted by kb0wcy on
  • 3 more comments
  • Anonymous Apr 11, 2008
    A AND B DECK PLAY FOR 5 SECONDS, AND THEN STOPS. FORWARD AND REVERSE. TRIED TO RESET UNIT BY DISCONNECTING POWER FOR AT LEAST 10 SECONDS, BUT SAME PROBLEM OCCURS.I JUST RECEIVED UNIT.
  • Anonymous May 04, 2008
    Brand new player played about 30 seconds of a brand-new tape, having the same issue on deck A. Tried power cycling to no avail. Where s the tape tension sensor so I can take a look at it?
  • Anonymous Jul 24, 2008
    Left(Playback) deck of cassette player turns off within about 2 sec's after inserting a
    cassette to play. Rewind and Fast Forward stop also after about 1 to 2 seconds.
    When pushing button to play it turns back off right away. I suspect the end of tape/tension sensor is the culprit but do not know where it is. Have not taken any steps except finding this site first off!
  • paulback Jan 10, 2009
  • Sam Palermo
    Sam Palermo Oct 28, 2013
    The motion sensor in the unit whatever it is is not working. Sometimes it is a belt from the reel table that turns a mechanism that keeps a piece moving to kep it from going into auto shut off. The belt if lose will not be turning this part. Look into the mechanism and determine what is linked to the reel table and determine how the auto shut off works. Once you know that the course of action becomes clear.
Anonymous
Left(Playback) deck of cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and Fast Forward stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. I suspect the end of tape/tension sensor is the culprit but do not know where it is. Have not taken any steps except finding this site first off!
Posted on Jul 24, 2008
Bruce Showalter
    Scholar:
  • 133 Answers
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Posted on Mar 21, 2008
2 Related Answers
Anonymous
  • 10594 Answers
SOURCE: Cassette Recorder play problem
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Anonymous
  • 382 Answers
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
2answers
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
1helpful
Wont play cassette
Usually when this happens it is either the "Pinch Rollers" or the "Drive" motor, has failed. You need to get it looked at.
3helpful
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Open Questions:
See all Onkyo TARW255 Single Dual Cassette Deck Questions
Top Onkyo Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
