SOURCE: display intermittant for few weeks, now no display or oven control
real easy trouble shoot, check the wiring diagram out and find where the line voltage goes into the board. if you have voltage to the board and no display it is very likely a bad board also make sure you have ground pathway from the board. you can have voltage to the board but if no ground pathway then the board will not work. a cheapo meter from sears etc. will work
SOURCE: range went into Sabbeth Mode?
refer back to you users care giude to de-activate the sabbath mode or go to www.servicematters.com to get the job aid tech manual
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Maytag CRE9500 electric range has
Hi , Jorland...
I have a CRE9500ADE and has fuses way behind the drawer under the oven,
there is a 15 amp fuse for the clock and controles the way see it.
Hope this helps...
SOURCE: Maytag MGR5770 Gas Kitchen Range displays OFF and nothing works!
That is normal, whenever you cut power the range goes in Off mode, that is a safety standby mode. The same as you first installed the kitchen.
No faulty thing and no need to take apart anything, do not disassemble the appliance.
The usual procedure to activate back the kitchen range is by downpressing the timer main wheel.
If this does not work, then there must be a different command, check the user instructions , or try playing withthe controls.
SOURCE: My Maytag MER5750AAA electric range
Can you please what happent before the problem occur and what massage you had or have on the display
