Boating Logo
Neil templet Posted on Sep 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
25 yamaha outboard 2 stroke was popping out of reverse now won't go into reverse !
Gordon Richard MacLean
Level 2:
Champion:
  • Expert 253 Answers
  • Posted on Oct 18, 2013
Expert
Level 2:
Champion:
Answers
253
Questions
Helped
77372
Points
481
Good Day To You Neil
Your Gear Linkage Has Been Miss Adjusted !
And It Has Caused The Shift Pin In The Gear Box To Be Worn.
You Will Probablly Have To Take It To A Repair Centre To Be Done For You , You Need Special Tools!
Regards
Gordon
5 Related Answers
Anonymous
  • Posted on Jan 05, 2009
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Anonymous
  • 710 Answers
  • Posted on Apr 27, 2009
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Anonymous
  • 187 Answers
  • Posted on May 12, 2009
SOURCE: speedo for a 80hp yamaha outboard
The sender is a plastic flip up fitting located at the bottom of the transom. They have two positions. Down and in the steam below the bottom of the water for reading the speed. Up to protect when trailering. Check to see if it is up. I never heard of a unit that is attached to the engine itself.
Anonymous
  • 53 Answers
  • Posted on Nov 01, 2009
SOURCE: Yamaha 115hp 2 stroke Outboard Boat Motor. Went
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
Anonymous
  • 53 Answers
  • Posted on Nov 03, 2009
SOURCE: yamaha outboard 150 4 stroke bad vibration at 700
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
2answers
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
