SOURCE: RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
SOURCE: Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
SOURCE: my dometic rv refrig is not working on electric
Check to make sure your getting 120 volts to the unit
Breaker tripped ?
