Question about American Standard 2004.014 - Champion Elongated One-Piece Toilet
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Posted by Jill L on
rplant
    New Friend:
  • 22 Answers
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Posted on Nov 11, 2013
5 Related Answers
co7196
Ned C Cook
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
snap101
snap101
  • 117 Answers
SOURCE: Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Posted on Aug 01, 2009
Anonymous
  • 3085 Answers
SOURCE: Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
Posted on Dec 12, 2009
Larry Maranto
  • 198 Answers
SOURCE: problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
Posted on May 09, 2010
Anonymous
  • 56 Answers
SOURCE: American Standard Carlyle. I think this is the
u will probly get a diagram with the pack u buy if u bay new sistern parts ,but its not that hard. pay atension to detail whan u disesenbel it. mostly to the rubbers and if u do have a leak use silicone. most rubers will be 1 inside 1 outside with washer holding it tight. sould be a breez bt if u are having any probs let me know im a proper plumber. wil coutch u threw. plz give me a reating. started using fixya tonight and if my advice helps ur rating wil help me help more ppl thx. o and if there is not a diegram in packet thast ask hardwear store to give u 1 or to exsplian. just gone on internet. they dont have 1 i can post to u sory. bt try and ill help u if u have a problem
Posted on Jul 08, 2010
American Standard 4061 toilet. Can periodically hear the toilet refilling when not in use. No visible issues. Replaced the flapper. Leak remains. No visible cracks on drain tube or tank.
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
Why does my toilet suddenly fill the tank?
Usually seeping is from under the flapper. Replace flapper with one designed for that model. Avoid generic flappers.
2answers
About every 20 minutes or so, more water is released into the bowl from the tank. Toilet is less than 1 yr old ,model 4021
The flapper that stops water from entering the bowl after flushing needs adjustment. The chain is probably to short.
Tiolet tops up tank every 10 minutes or so.
With the toilet tank topped off, turn off the water supply. Then put a generous amount of food coloring in the tank. Wait ten minutes. If you see colored water in the bowl it will confirm that the flapper is leaking and needs some adjustment or to be replaced.
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
1helpful
Problem: water tank running water and refilling itself
I have a American Standard Carlyle, with a leak that keeps filling up tank. Have replaced flush valve, flapper, and refill. Put food coring in tank, and water is coming into bowl at the bottom of bowl, not...
Yes it must be cracked between the tank and bowl . Take a #2 pencil and and rub it back and forth inside the tank that should show the crack. Good Luck
Dec 01, 2009 • Home
1helpful
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
4helpful
5answers
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
American Standard 2004.014 - Champion Elongated One-Piece Toilet Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
