Question about Bell & Howell Video Cameras
The cord that came with it could it be broken. I plug it in nothing. Where can I get a new one?
Posted by Tracy Nickels on
  • Tracy Nickels Sep 21, 2013
    I'm going to buy another camera.
1helpful
I have a Coleman mach RV roof Ac with a fan and separate Furnace unit. None of the units will turn on.The AC did work along with the fan. Now nothing works. All of the fuses are good
Check the plug end of the Power cord for a broken wire. If you can test the cord for continuity with an ohm meter do that first. Most likely you can get a replacement plug. You'll need to cut the old one off and strip the wires back to connect the new plug.
I opened the vacuum,i checked the cord and it is in the correct form,not tangle etc..still doesn't work after pluging it the wall out let..help
Possibly a broken wire. It is common for the flexible cable to break at the 3 pin plug end from constantly pulling the cord / plug out of the socket or if its a retractible cord, they get broken where the cord enters the machine rewinder. this happens when the cord is pulled out to its maximum length all the time and eventually cuts through the cord. I would try a new 3 pin plug first.
Apr 13, 2015 • Vacuums
120gb Zune won't turn on or charge
No probley not it needs a new battery more than likely they can be bought for around $25.00 or so no fun to put in very delicate.
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
I plug in cord to charge unit. Light goes on. I put unit down, light goes off. I twist cord, light flickers. I lift unit up and twist cord light goes on. I put unit down or lie it down light goes off. Unit...
You have to use the same diagnostic procedures that you already have to isolate which area of the cord is broken. Carefully test, by wiggling, etc. the end of the cord that plugs into the wall. If this end is faulty, you can purchase a plug end at a hardware store and replace it.
If the cord is broken at the sweeper end, unless you can open and repair the break, you will probably need a new charger.
Gary
Feb 21, 2011 • Vacuums
Trimmer won't operate, is less than year old. Connect to cord and won't operate
Try something else (a lamp) in the extension cord. If ok, the case must be opened to expose the wiring. Check for 110-120 volts AC at the cord ends. If nothing, the plug end may have a broken wire. Cut back the end somewhat and install a new plug or just replace the power cord. If still nothing, remove the power connection and ohm-check the switch and motor. The switch should read zero ohms when on and the motor will usually read less than 20 ohms if good. If either reads infinity, replace the switch if so, and check the motor brushes for sticking or bad springs.Hope this makes sense and helps!
Apr 17, 2010 • Garden
3helpful
2answers
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Laptop doesn't register USB cord of printer
You may well have damaged the cable internally. Change it for a new one . Not expensive.
Power cord plugged in no lights on power brick
ring xbox tell em u didnt do anything to it and its just broken they sent me a free new one :) so they should u it was with me after 2-3 days
so get a new free one and end any future problems
Video Cameras Logo
Top Bell & Howell Video Cameras Experts
ray gallant
Tom Chichester
Tony Parsons
Tony Parsons
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
