Question about Dell XPS Computers & Internet
Shut off hibernate mode - XPS Dell Computers & Internet
Posted by jan baskins on
Brian Bromell
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
Hybernate mode is typically shut off through your laptop's power options accessed through the control panel. It will outline what actions to take and when including hibernation and sleep. Aside from power options some operating systems have power options when you rightclick your desktop and go to preferences/display
Posted on Sep 19, 2013
Hibernate mode
Go to Control Panel>>Power Options>>System Settings. You can turn it off from there.
Sep 19, 2013 | Dell XPS Computers & Internet
Tip
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 | Computers & Internet
My sony won't shut down. it will only hibernate
Go to power options and uncheck hibernate mode.
May 10, 2012 | Sony VAIO TR2A Notebook
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
Mar 11, 2010 | HP Pavilion dv2715nr Notebook
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Compaq 714NR shuts down when hibernating
go to www.hp.com and update the bios looks like a problem with the hibernation ,mode
Jul 20, 2009 | Computers & Internet
Hibernating
What do you mean shutting down the hibernating mode? Stop it happening when the battery goes low, or shutting down into hibernate mode?
Aug 20, 2008 | Compaq Presario Notebook
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Open Questions:
Computers & Internet Logo
48 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
