SOURCE: Power won't come on
I have the same issue, i tried what you said above but it did not work at all, any other solutions at all, or should I just dump it ???
SOURCE: Headset will not turn on
hello to you, ahh yes the wonderful world of moto, it sounds to me like your not letting it charge long enough, when you start the charge it will go red, than after a bit it will go yellow and when fully charged it will go to a real dark green.( some times up to 3 hours, no!! im not kidding,) it amazes me how long it takes. step 2. when you want to put it in discover mode press the call button in till it turns solid purple than pull the mike down real quick and it should stay purple at this point you have 30 seconds to pair that puppy. good luck and you will get used to it. hope you only have one. i have seven.
SOURCE: H700 Motorola Bluetooth Headset
Make sure that any devices previously paired
with the headset are turned off. If the indicator
light is flashing in blue, turn off the other device,
then close and reopen the headset boom. The
indicator light becomes steadily lit in purple
indicating the headset is now in pairing mode.
SOURCE: H700 Motorola BT earpeice, no indicator lights aside from a green
Same thing happened to me. I call the support center and if you bought it from a 3rd party, it is probably a software problem. See if you can get a new one or buy it elsewhere.
SOURCE: Green light stays on....headset not turning on
I have had no trouble with mine (3+ months of good use) until today. Same problem you had - green light won't go out, unit won't turn on. Jonsumer's solution got me to thinking, and this worked for me:
1. plug the charger into the wall.
2. plug the headset into the charger.
3. unplug the headset from the wall.
Plugging & unplugging the headset to charger multiple times had NO effect. It was only when I plugged it into the charger and unplugged the charger from the wall that the green light turned off and the headset began to work normally.
