Question about Tag Heuer Clothing Accessories
I need booth of the earpieces of my sunglasses Tag Heuer TH5019, can anybody help me?
Posted by Mauro Marchi on
5 Related Answers
Brian032472
Brian032472
  • 150 Answers
SOURCE: Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Posted on Nov 06, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
  • 3 Answers
SOURCE: Tag Heuer Formula 1 Mens watch
battery number 395!
Posted on Jan 02, 2009
Anonymous
SOURCE: Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Posted on Jan 10, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Does anybody know the correct part number or provide a link where I can purchase a Bezel ratchet spring for Tag Heuer WAC1113.BA0850 Formula 1?
Hi thank you for answers but it doesn't help me given I already have the bezel off. What I actually need is the actual size of the Spring? I know they are available to buy on eBay and watches.com.uk but to not even bother to respond to you inquiries for some reason?
Does anybody know the correct size of the "friction/ ratchet bezel spring" on a Tag Heuer WAC1113.ba0850 model 2004 - 2007 ?
May 11, 2016 | Tag Heuer Watches
Scratch on my tag heuer sunglasses lens
Hi Karen,
there are a number of places that specialize in replacing scratched or broken sunglass lenses.
www.thesunglassfix.com is probably the largest out there and known for good quality at a great price. However, there are others like fuse.com and your local optomentrist that may have the lenses.
Most offer the option of having the lenses sent out to you or you sending in the frames to get new lenses.
Have tried many of the "buffing out scenarios above" and my personal opinion is they don't work and only make matters worse. Getting new lenses can cost as little as 10% of the purchase price and complete resolves the issue for years.
Good luck Craig
Sunglass Replacement Lenses for all Sunglass Brands
Feb 14, 2012 | Tag Heuer Clothing Accessories
I have a pair of Tag sunglasses. I believe the model number is 6008 102 but the full numbers that are on one temple are 115/1 30 TH 6008 102 59 1703. There is a rubber nose piece that is mounted on a...
go to the official Tag Heuer website, www.tagheuer.com, look for the retailers in your country chose the one nearest to you and contact him The name of the model is TH 6008 102
May 17, 2011 | Tag Heuer Clothing Accessories
The ear holder broke, where can I find a replacment in las vegas ?
Hi.
Go to the mall, there is a store there called "The Sunglasses Hut".
They carry the earpieces in stock for all the major brands of sunglasses, and they should have one for your TagHeuer shades as well.
I hope this helps you out, and have a nice day !
Apr 23, 2011 | Tag Heuer TH 2005 Sunglasses
Replace rubber nose pieces
use small pin or maybe hairpin to unclog the said rubber.
Feb 01, 2011 | Tag Heuer TH 5104 Sunglasses
I bought a pair of TAG Heuer sunglasses on 08/26/ 2010 and yesterday the right arm broke! I have my receipt and the box they came in. I know they are warrantied, but what do I do? Thanks, Donna Jones
I would take them back to the shop you bought them and they will either take them and replace them or give you an address or phone number for who they should go to
hope this helps
Jan 26, 2011 | Tag Heuer Clothing Accessories
Need to know where I can buy replacement nose bridge for the 1004 series of sunglasses
hi
i dont think it will be a problem ,did you try approaching the dealer who deals with your brand if you have warranty it will be done free of cost . if your brand dealer cant help please try approaching any one dealing with sunglasses i am sure they will solve your problem it wil be done cheap.
thank you
Dec 28, 2010 | Tag Heuer Clothing Accessories
Clothing Accessories Logo
Top Tag Heuer Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Tag Heuer Clothing Accessory Expert? Answer questions, earn points and help others
