Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
Se309 R12 - Whirlpool ET8WTKXK Top Freezer Refrigerator
What kind of gas should be used in Subaru 1993 air conditioner to work? Is it R12?
Most a/c units up to 1995 use R12.
Any R12 system can be converted to 134A and will be colder on 134A.
Jun 16, 2017 | Subaru Cars & Trucks
91 Mercedes 300 E has R12 ac system that is no longer blowing cold. A faint bit of cool air sometimes shows up but it can hardly be called cool. Is there any additive out there compatible with R12?
Propane does the same as R12. I don't recommend it though(highly volatile). Best to convert to 134R. Last time I converted an R12 system was about 10 years ago. I would tell you how to do it, but I could get in trouble because you have to vent out the R12 first. I don't even know of a shop that has an R12 unit anymore. Good for you, they still have the adapters to go over your ports and the 134R today is compatible with the old systems oil. No need to change the compressor, dryer, and expansion valve.
Jun 06, 2016 | AC Cars & Trucks
R12
Most everything built before 1994 used R12 freon. And you must have a license to buy R12 in most countries.
A shop can convert the system over to R134.
Jun 12, 2013 | Toyota Cars & Trucks
What type of refrigerant does a 1990 Ford Ranger use?
there are only two types of refrigerant (or normally called as freon): R12 and R134. R12 is designed for car model 2000 and below. though, some old car compressors can accomodate R134 provided that you change your auxillary fan (fan for your aircon condenser) since R134 is hotter than R12. Ask an aircon technician if your compressor can be charged with R134.
Most of the countries now ban the use of R12 since it is more harmful to our ozone.
Aug 05, 2011 | 1990 Ford F150
Can i use r134 referigerent in a R12 compressor
yes but you need to rcover r12 then retro fit the hi side and low side then vacume system then when you ad r134 you only ad 80 percent of what the original amount of r12
May 18, 2011 | 1995 Chevrolet K1500
What is the refrigerant in my 1991 LS400 Lexus?
R12 is not sold no longer so look on the compressor for a tag of what freon to use. Conversions kits are sold for older cars to use R134a
Jul 10, 2010 | 1991 Lexus LS 400
MY FORD TAURUS 1996 IS RUNING AND SUDENLY STOP AND IS DEAD, WHY.
tv1709~us~en~file=adobe.gif~gen~ref.gif Printable View (11 KB) Article No.
97-17-9
  • STALL - ON DECELERATION AND/OR INTERMITTENT STALL IN WARM WEATHER - VEHICLES BUILT THROUGH 8/18/96 AND SHO BUILT THROUGH 8/6/96
Publication Date: AUGUST 18, 1997
FORD: 1996 TAURUS SHO, TAURUS LINCOLN-MERCURY: 1996 SABLE This TSB article is being republished in its entirety to correct a service part number. CALIBRATION: 6-10A-R07, 6-10A-R10, 6-10A-R11, 6-10A-R12, 6-10S-R07, 6-10S-R10, 6-10S-R11, 6-10S-R12, 6-10B-R06, 6-10B-R10, 6-10B-R11, 6-10B-R12, 6-10T-R06, 6-10T-R10, 6-10T-R11, 6-10T-R12, 6-14A-R07, 6-14A-R08, 6-14A-R10, 6-14A-R11, 6-14S-R07, 6-14S-R08, 6-14S-R10, 6-14S-R11, 6LDA-JAD tv1709~us~en~file=caution.gif~gen~ref.gif WARNING: THIS MODIFICATION IS AUTHORIZED ONLY FOR THE LISTED ENGINE. PERFORMING THIS MODIFICATION ON OTHER ENGINE CALIBRATIONS IS UNAUTHORIZED AND COULD CREATE LIABILITY UNDER APPLICABLE FEDERAL OR LOCAL LAWS. ISSUE: Some vehicles may stall on deceleration and/or have an intermittent stall in warm weather. This may be caused by the vapor control valve not supplying a steady flow of fuel from the tank to the intake manifold.
ACTION: Replace the fuel tank, vapor control valve, fuel fill tube cap and clamp. Install heat shield over fuel tank and reprogram the Powertrain Control Module (PCM). This should reduce the possibility of stalling. Refer to the following text for details.
Perform all diagnostics for stalling by following the procedures outlined in the 1996 Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual and 1996 Taurus/Sable Service Manual, Pages 03-13-5 through 03-13-8. Check to be sure Grounds 401 (sedans) and 400 (wagons) are secure. Check for a kink in the canister vent hose and repair as required. If no other concerns are found, reprogram the PCM using the latest level CD-ROM update disc and refer to the following PCM Application Chart for correct PCM usage. Replace the fuel tank, vapor control valve, and vapor management valve by following the procedure outlined in the Instruction Sheet included in the Fuel System Service Kit.
PCM APPLICATION Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 6-10A-R07,R10, R11, R12 F6DF-BF 6-10A-R12 F6PF-CVB 6-10S-R07,R10, R11, R12 F6DF-DF 6-10S-R12 F6PF-CYB 6-10B-R06,R10, R11, R12 F6DF-JD 6-10B-R12 F6PF-CXA 6-10T-R06,R10, R11, R12 F6DF-KD 6-10T-R12 F6PF-CZA 6-14A-R07,R08, R10, R11 F6DF-EG 6-14A-R11 F6PF-CGA 6-14S-R07,R08, R10, R11 F6DF-FG 6-14A-R11 F6PF-CFB 6LDA-JAD F6DF-RD 6LDA-JAD F6PF-CDA
Sep 01, 2009 | 1999 Ford Taurus
Have a 1986 F-350 A/C puts out cool air but not cold. Don't know if system is R12 or 134A. Compressor is centr and has 2 threaded black caps with schrader valves for gage connection plus 1 quick disconnect...
in 1986 it is r12 but you can convert to r134 which is a ton cheaper than paying for r12 you need a license to buy r12 r134 is right on the shelf at auto zone they also sell retro fit kits with everything you need to convert your system and they work very well
Aug 18, 2009 | 1998 Chevrolet Cavalier
How much to recharge A/C unit in 92' Buick LeSabre?
Depends on if it takes R134 A or R12 refridgent. R134A most likley looking around $150 depending on amount of freon the system holds. if its R12 open your piggy bank cause its going to cost you some coin as R12 is no longer in production you have to convert your system to R134A or find a gararge that still has some R12
Jul 31, 2009 | 1992 Buick LeSabre
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
150 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
