Question about Juicers
How to reset ACM - Juicers
Posted by evans ndaro on
Omega juicer 1000
Could be a defective breaker. That's what the "reset" is.
Jul 23, 2016 | Omega 1000 Juice Extractor
The juicer quit working while we were using it; the motor was hot. Any reset?
It might work when it cools down as some reset themselves. Some have a thermal link which blows on overheat and needs replacing.
If the motor itself has burned out, it will not be an economical repair.
Dec 28, 2015 | Juicers
I need manual for audio centron acm 1406 sound mixer
Got a PDF Manual a audio centron ACM 1406 contact me at [email protected] if you want a copy
Dec 21, 2011 | Juicers
A small slice of cabbage got stuck at the bottom of the funnel where the vegetable goes onto the blade. The motor stopped immediately and is now not working. This same mishap happened about a year ago...
A small piece of cabbage should not stop this machine. If it did stop, look for the red reset
button on the bottom of the juicer. I've been using mine for 21 years and occasionally it will
stop when run for an extended period especially if vibration is present. In each case I waited
a few minutes and pushed in the reset button.
Mar 29, 2011 | Acme 6001 Juice Extractor
My B& D juicer stopped working after juicing oranges. Is there a reset button?
If you know your model number you can search for the Use and Care Manual here:
http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
The manual should state whether there is a reset button.
If you need help searching for the manual reply with your model number.
Dec 06, 2010 | Black & Decker Juicers
My Acme supreme juicerator #6001 trips off several times before I can complete the process of juicing in order to get an 8oz. glass of juice. The motor spins smoothly, no vibration at all.
There is a reset button on the bottom of the
juicer. You will have to separate the base
by removing the 4 bottom screws and adjust
the sensitivity of the reset button turning the
small screw on it. Sorry, but forgot which
direction increases or decreases this. Had
to do it on my 21 year old Acme because of
the same problem.
Apr 22, 2010 | Acme 6001 Juice Extractor
Motor failure
First, turn off the power at the circuit breaker and look for a small reset button. There should be one. If not, leave the juicer on off - and turn the circuit brkr. back on, and try again. If this still doesn't work. Check and see if you're plugged into a GFI receptacle, which has a little reset button on it. In fact, you can check this first. Good Luck to you! Feel free to contact me again if this doesn't work for you. - Jim
Mar 29, 2010 | Breville BJE200XL 700 Watts Juicer
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Oct 06, 2007 | Acme 6001 Juice Extractor
Juicers Logo
105 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
