Compaq tc1100 Tablet PC Logo
Tessa ann Posted on Sep 19, 2013
I want to reset everything on the tablet - Compaq tc1100 Tablet PC
michael
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 25, 2013
michael
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
496
Points
12
Go to settings it should have a memory reset
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
What wrong with a tablet when everything is backwards
Try a reset. There is a reset pinhole on most tablets to do this.
Check your manual if you have one or try to find one online.
You open a paperclip and put it into the reset hole and push gently. This will cause it to shut down and reset to factory default.
Something is wrong with your operating system to cause that.
You will lose any data or apps you might have saved.
How to reset Tablet?
To reset the tablet, go to "Settings", then "Backup and Reset" -> "Factory Data Reset" -> "Reset Tablet" -> "Erase Everything", and the tablet will shut off and power back on automatically one the reset is complete. Please make sure tablet is fully charged or connected to the power supply before starting.
Support Troubleshooting Guide
Locked out of tablet
You could try to factory reset the tablet but that would delete everything you installed and downloaded unless you had everything backed up
How do i reset my asus tablet
Step 1. In the device,select settings on the application list >select back up and reset >factory data reset >reset tablet >erase everything. step 2 . The system will erase all user data and reboot automatically. Please note all data will be erased from tablet!!! 12_22_2013_7_37_26_am.png
2answers
Top Compaq Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
