Question about Invacare Supply Group Health & Beauty
I have a Invacare zoom 200 scooter,it slows down and almost comes to a stop then lurches forward very fast,it also makes a chattering noise backing up.
5 Related Answers
Anonymous
  • 32 Answers
SOURCE: Reverse on 3-Wheel scooter won't work.
throttle pot, cheap fix
Posted on Apr 03, 2009
Anonymous
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Posted on Jun 18, 2009
Anonymous
  • 86 Answers
SOURCE: scooter stops then jumps forward
mait be problem with moter
Posted on Feb 20, 2010
Paul B
  • 61 Answers
SOURCE: My Scooter slows waaaay down to almost stop, then
Sounds like a throttle pot fault (the part that the throttle lever is attached to). This would need testing at a dealer or with a volt meter (set to ohm's) and if found to be faulty, will need replacing. If you test it yourself, there is usually a number on the top of the pot, usually 5k or 20k and this is what you need to set your meter too. Place the probes from the volt meter, black onto the centre wire and red onto either of the other wires (there should be 3) and slowly press the throttle lever first forward, then reverse, and constantly keep an eye on the reading from the volt meter. The reading should go up to approx. the number on the top of the pot, i.e. a 5k pot should read about 4.9 to 5.1 ish on the meter. If this number fluctuates up or down quite rapidly while the lever is held in a static position, it will indicate a faulty pot. This is in fact a common fault with nearly all makes and models of scooter and usually a fairly cheap and quick repair.
Posted on Mar 29, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
Posted on Jun 23, 2010
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
Oct 16, 2014 | Invacare Pronto M61 with SureStep Rehab...
Invacare meteor, keeps slowing down, then speeds up again, can you help.
usual cause of this is the throttle (wig-wag ) controll potentiometer has worn out.to test put the scooter against a wall and get a freind to lift up the rear of the scooter and put 2 large blocks of wood underneath it so the back wheels can rotate
carefully advance the throttle 1/2 way then with wheels turning.keep in same position and gently move the throttle lever up and down .if there is a lot of play and the speed varies drasticaly then pot replacement reqd .you can get a dealer to order the correct one or get one off the internett but when fittinf if thr pot is not set to exact center with multimeter scooter will not move and produce off center error code
Sep 27, 2014 | Invacare Health & Beauty
Go go traveller mobility scooter lurches forward when finger is released off forward control lever. mum has problems getting it to move forwards smoothly and slowly without it suddenly moving forwards...
That lever is attached to a pot. Pots have this nasty habit of oxidizing. You can either replace it or get some CRC QD Contact Cleaner. Wash it down trying to get as much cleaner into the pot as you can. These pots are normally not sealed find a little hole and spay it there. While your in the control head use the cleaner to clean anything you find in there. Stall having problems contact me.
May 30, 2012 | Health & Beauty
Car drives fine but when i slow down to a stop it begins to stall and lurch forward. the brakes also lock up and the steering sometimes to if i accelerate fast enough i begins to drive fine but if i slow...
The 1995 Grand Am was GM's worst nightmare. At 120,000 the transmission is going to just blatantly fail on you w/out notice. Problems with this make and model is if it was created between 1995-96 the transmission problems are goin to start. Even if you swap the crankshaft sensor, ignition module, and coils. I had one go at the mileage i just submitted. The computer also has malfunctions. It is indeed time to rid your vehicle, Sorry. Thnx 4 using fixya.com :-)
Apr 01, 2011 | 1995 Pontiac Grand Am
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Oct 03, 2009 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
83 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
