SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
SOURCE: Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
SOURCE: 42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
