Question about ZEEPAD Tablets & eReaders
Reset android I received my ZeePad 7.0 4.1 Jelly Bean today. The WiFi wouldn't turn on. I tried the different troubleshooting ideas that were sent with my device like restarting my router and my tablet, holding down the power button to do a reset and then did a factory reset. After I did the factory reset, I tried to turn my WiFi on again and ended up getting a black screen with the word android in the middle of it. What do I do now?
Posted by Kristina McInnis on
5 Related Answers
Stephen baynes
  • 394 Answers
SOURCE: Ii have the Coby 7005
Hi, I am Steve, lets help solve your issue.
I am afraid the information you have been given is completely wrong. There is not such thing as plug and play in the android world. Android was initially developed for use on embedded devices and as such had no need to recognise external devices automatically. Version 2.1 (as installed on your device) is now quite old and cannot support it. Even the new version (froyo -2.2) does not support it.
Your device does come with a built in wireless adaptor, so you don't need a USB wireless adaptor.
Posted on Jan 15, 2011
agc93
Alistair Chapman
  • 44 Answers
SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps, Alistair
Posted on Mar 15, 2011
brimknows
Jason Fisher
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
jesus zuniga
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Posted on Dec 28, 2011
Jehnavi
  • 4 Answers
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12 mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to gather around on the sofa at home or slip into a carry case for when on the go".
Archos Arnova 10 G2
Posted on May 19, 2012
My battery wont re charge
Try a different charger, if this doesnt work you'll have to consider replacement or repair. Hope this helps, Graham
Oct 19, 2014 | Simbans TM S74B 7 Inch Tablet PC - Dual...
Zeepad instructions
Please try this:
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
Aug 31, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Why does my 7" android series only display android on the screen when turned on ,does this need rebooting and if so how do i go about it?
So it only says android and never loads to the point you see the screens you are used to?
Sounds like a failed update or something. Look up and perform a factory reset. It's usually a button holding down combo but I don't know what yours would be.
Jul 20, 2014 | Acer Iconia B Series B1-710 with WiFi 7"...
Www curtisint com
Try doing a reset or hard reboot.
Jul 15, 2014 | Irulu 7 Inch Android 4.1 Jelly Bean...
How do I fix a blue screen on my zeepad jelly bean tablet
See this site... http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
Jun 30, 2014 | ZeepadTM 7" Zeepad 7.0 Andoid 4.0...
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 10, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Manual for zeepad jelly bean 4.2 version
I need a readable Manual for the zeepad jellybean 7" screen
Jan 14, 2014 | ZEEPAD 7.0 Capacitive Touch ceen 512/4G...
Screen shots
swipe your palm across the screen slowly... this should take a screen shot you may need to enable this in settings but this works for an s3
Jan 07, 2014 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Tablets & eReaders Logo
48 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Paul G
Paul G
Ngoro
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
