Question about Juicers
How do I get the top of the juicer off for cleaning
Posted by sharyn foster on
How do you take the top off to clean the bottom container after use?
The manual for your Jack LaLanne Power Juicer can be found here:
http://www.powerjuicer.com/power-juicer-manuals.php
The manual contains illustrated assembly and disassembly instuctions
You may also find the How To videos to be helpful:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
Aug 01, 2011 | Jack Lalanne Power Juicer 250 Watts
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
I need to clean my Jack Lalanne power juicer.
is a manufacturer secret- I think you need to keep the juicer dirty
Mar 17, 2010 | Jack Lalanne Power Juicer 250 Watts
I don't know how to clean my jack lalanne's power juicer
remove to arm that holds top slide it twards you then use tool to remove blade then remove juicing screen then the bowl (the one that says jacklallanes power juicer
Mar 02, 2010 | Jack Lalanne Power Juicer 250 Watts
How do you get the top of for cleaning on the jack la lane juicer
Jack Lalanne Juicer Manual
http://www.myeasypics.com/is.php?i=665112&img=1.jpg
http://www.myeasypics.com/is.php?i=665113&img=2.jpg
http://www.myeasypics.com/is.php?i=665114&img=3.jpg
http://www.myeasypics.com/is.php?i=665115&img=4.jpg
I hope this helps.
Nov 09, 2009 | Jack Lalanne Power Juicer 250 Watts
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
99 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
