Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Wiring motor for Hayward pump but it's running counterclockwise...is this right?
Posted by mike lapiana on
Juan Rivera
    Novelist:
  • 172 Answers
No is not right if you have replaced the motor on the label can tell you what wires to chnage to meke it run in the right diretion
Posted on Oct 06, 2013
3 Related Answers
john224
John Prohaska
  • 1378 Answers
SOURCE: wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Posted on Jun 13, 2009
john224
John Prohaska
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: I need to verify the wiring on a Hayward MaxFlo II
Posted on Sep 08, 2011
How do I remove impeller from motor? Is there bolt or does it screw off? It appears head of bolt is sheared off.
The impellar spins off counterclockwise on most pumps. The hard parts are holding the motor shaft from rotating and finding a way to grip the impellar.
Gary
Jul 24, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My hayward super II pump is cycling between hign and low speed every i second until it overheats and shuts off. What could be the problem
VOLTAGE IS SET FOR 230 AND YOU ARE RUNNING IT ON 120V BACK OF THE MOTOR HAS A WAY TO SET THE VOLTAGE.LOOK ON TOP OF THE MOTOR FOR THE WIRING SCHEMATIC . THERE IS A START AND RUN SPEED.. HOPE THIS HELPS VOTE Jay
Jan 30, 2011 | Hayward 1.5hp 230v 2 Speed Uprated Super...
I just installed a New 1 hp Hayward Super Pump. The electrical service is a 20amp GFCI breaker> Old pump was a plug in connection, re-used the existing wiring. I changed the internal connection on the...
I see what you said ... still I want to say the following: It is to your benefit to keep the motor at 220 VAC ... Since you want to run it on 120 (I presume the motor is internally wired for 120 now - right?) did you change the white wire in your pannel to the neutral bus making the line 120? Also check the motor that it is wired for 120. It sounds to me like you did the line but not the load.
If the line and the load are both correct the next thing to check would be the start capacitor. It should be good since this is a new motor ... but it is not running. Have it checked.
May 24, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Clicking noise in new Hayward Super Pump
It sounds like the wear ring on the impeller is hitting the diffuser. If it is new call Hayward to fix it under warrenty
Best of luck
Jun 04, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward Heat Pro Electric won't stay running
from the Hayward support site....
Why is my pump cutting off and on every 5-10 seconds?
  • Hayward motors are factory wired for 240 volts unless the motor is 120 volts ONLY. Check the voltage of the incoming supply power and ensure the motor is wired or can be wired for this voltage (data plate on motor will help provide voltage and wiring information). Also check for loose or badly connected wires. Contact a certified electrician for repair.
Sep 24, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
77 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
