Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Mac laptop i 8 i k, keys not working - Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
I have windows 8 disc but lost activation key. It's a apple mac book pro. It's just been formatted and I'm trying to re-install windows 8. Help
You're going to absolutely need the CD-KEY in order to activate and use the OS longer than a few weeks. There's really no short cut around this. Since you've already reformatted the drive, you can't even use Magical Jellybean to scan the drive for the key.
KeyFinder Magical Jelly Bean
Have a look at the case of the computer to see if the is a CoA (certificate of authenticity) sticker on it. The CD-KEY will appear on this sticker.
Feb 24, 2015 | Apple Computers & Internet
Tip
How to invert the screen color of your mac book
you have to press "Control", "Alt/Option",Command Key(right next to the Alt/Option key)+8
so you have to press control+alt+cmd+8
on Jul 31, 2010 | Computers & Internet
Tip
Make reading documents easier on the eyes
Hold down ctrl, alt/option and command keys and press 8. You will invert the display and make reading documents much easier - especially in a dark room. Press again to return to normal.
on Jan 08, 2008 | Apple iBook Mac Notebook
Why doesn't my bottom arrow key work?
You may have something stuck under the key. You can try lifting the key a little or even taking it off and cleaning under it.
Aug 08, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Eject disc from mac
press the key on the top right corner
- if that doesn't work restart the mac while holding down this key Vincent Gables Blog 23777320-ejrezfb3hre2tkh0bmqfk3s3-3-0.jpg 23777320-ejrezfb3hre2tkh0bmqfk3s3-3-2.jpg
Mar 09, 2014 | Computers & Internet
My mac screen is on x ray mode how do I change it back
Press the Control-Option-Command-8 key combination.
Aug 19, 2013 | Computers & Internet
Macbook asterisk
make sure there was nothing spilled on it next you can try to take off the key and clean it with a compressed air.
Jun 16, 2013 | Computers & Internet
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jun 06, 2012 | Apple MacBook Air
Powerdirector 8 delux
No you cant use Power Director in your Mac Os X. But if if you load Win XP in mac u can use it.For Mac OS you can use FCP or AVID for video editing.
Apr 10, 2010 | Apple MacBook Mac Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
250 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
