Question about Necchi 3102 Mechanical Sewing Machine
How do you load the bobbin in a Sunbeam SB 1800 sewing machine?bobbin
1 Related Answer
Anonymous
  • 66 Answers
SOURCE: How do i thread the bobbin on my necchi 539
take out your bobbin and turn it the other way
Posted on Feb 03, 2009
My Sunbeam SB1818 needle will not pick up bobbin thread so I can sew what do I do
make sure tat there about 6" of bobbin thread hanging out after you put the bobbin back in the bobbin holder
increase the needle thread tension up more thread tension should be a slight drag as you pull the thread out to thread the needle
Oct 30, 2016 | Sewing Machines
Sunbeam Sb 1800. What should I do to oil it?
there is only one place I oil this machine , and that's in the bobbin area , all the parts that move inside there could help with a drop or two of oil ,(not covered) the gears in the lower unit (bottom) should be greased once a year to prevent wear , Not any grease will do , as most car type greases will dissolve plastic gears found in these , use only grease safe for plastics , in fact its such a problem most mfg say not to grease them at all, just let em wear out and replace em
Feb 09, 2016 | Sewing Machines
I don't have a needle for my sunbeam sb1800 sewing machine. Im not sure what size it requires. Please help me!!
The stem of the broken needle may have a number or letter of the type of point you had. I believe the stems are all the same size, or that it doesn't matter as most are secured with a thumb screw.
Here is an article about the tips of sewing needles and how to choose them:
http://www.sewmamasew.com/2009/06/sewing-machine-needles-how-to-choose-them/
Mar 08, 2015 | Sewing Machines
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
White sewing machine model 1620
yOU CAN GET COPY OF THE MANUALS FREE AT 1800-446-2333
Aug 28, 2008 | White Sewing 935 Mechanical Sewing Machine
Necchi 3102 Mechanical Sewing Machine Logo
334 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
