Question about Hitachi 50DX01B 50" Rear Projection Television
Tv for cash - Hitachi 50DX01B 50" Rear Projection Television
I had a tv stand on layby unfortunately i lost my job before completing payment now the retailer says he cannot give me a cash refund
The easiest go around would be to get the cheapest thing there and demanding the remainder in change, sort of as a cash back option, he should not be able to refuse this even if he doesn't like it. Try going to a cashier or someone without him noticing as you do it, while a little sneaky it most likely will result in less trouble. If you still cannot get through this way you are going to want the most "liquid" thing you can get, meaning you want something that is easiest turned back into cash whether through someone you know would want and pay for it or even someone in the store wants and you could get as much of your money back as possible. Good luck and remember be calm, getting angry will only make things more difficult. You can rant once you've got your money back.
Nov 21, 2013 | Panasonic 37" Plasma TV TH-37PV70 + Stand...
I have reinstalled an Epson TM-T88II in a POS system that does not have a parallel connector. There is a D-Link fast ethernet print server model DP-301P+ connected to the parallel port of the printer. An...
The cash drawer is loking for a signal from the printer to fire the drawer. It is usually on one of the pins of the cable comming from the printer. You will probably have to contact the cash drawer manufacture for that information.
You can contact Southeast Digital Networks, Inc. for more info.
Tel 850-681-9528
Hours of operation Mon - Fri 8:00am - 5:00pm EST
Mar 06, 2011 | Epson TM-T88III (C420863)
Sony TV has "green video"
Ummm. Take the $1133 in cash and buy a Sony KDS-60A2000.
Possibly call Sony customer relations, they may cover repair. I know this is possible.
Jan 18, 2011 | Sony KDS-60A2000 60" HDTV
How to open cash drawer epson tm-t88ii printer
You need to have the correct cable to connect your cash drawer to that printer. What model of cash drawer do you have?
Apr 20, 2010 | Epson TM-T88III (C420863)
How do I get the cash drawer to pop using the Epson TM-T88III and windows driver? I am currently using RMS as our point of sale system but do not want to use OPOS drivers as this printer and cash drawer is...
You can set this up under printer settings - Under Windows XP - At the control panel, click printers, right click the tm-t88iii printer and select properties. Click the 'Device Settings' tab and there *should* be a option to open the cash drawer after printing.
Nov 06, 2009 | Epson TM-T88III (C420863)
Cash for broken 54'' akai rear projection
yes maybe i have one that i have barley ever use and after eight years it now have only a green and blue picture and i can't find anyone to fix this set because i live in Tyler, Texas.
Apr 03, 2008 | Akai PT5492S 54" Rear Projection...
Help
ok this is gonna be a bit complicated, you need to put your cashe on a different drive (other than the C: drive) because when you watch TV the computer will use memory if you don't have enough memory the computer then takes disk space and uses it for memory called cashe, moveing your cashe to a different drive will improve the performace of your computer because everything you have runs off the C: or root drive the less access to this dive during acctivities the less freeze up will acure, or you can purchase more memory, you might want to defrag your computer as well, I have 4 drives on my maine computer 2 300 gig drives C:, D:, E:, and F:, C: is my system drive, Cashe drive is D: so when my computer goes for virual memory it does not affect C: and I hardly notice, hope this helped you
Nov 04, 2007 | Acer Aspire 5610-4648 Notebook
Hitachi 50DX01B 50" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
