Question about Bosch Ovens
The clock on my Bosch double oven is showing c31 and when i press the button it gies to c32 etc..
What has happened ? how do i reset it , oven isnt even a year old
  • Tim Heath
    Tim Heath Feb 24, 2020
    The Bosch c codes are not error codes. Refer to 'Changing the basic settings' in the manuals, e.g. c1.1, c2.2, c3.2 defaults. They relate to default times for: c1 the time display {1 always on/ 2 off} / c2 timer alarm duration {1 10sec, 2 2min, 3 5min} / c3 set cooking times delay till activation after setting a time {1 2sec, 2 5 sec, 3 10sec}. Pressing / touching the (clock dial) symbol for 4 seconds will activate / save the settings, or power cycling the oven off/on will also cancel this function.
Ngoro
    Top Expert:
  • Bosch Master
  • 2,715 Answers
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
Anonymous
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
laneycath
  • 3 Answers
SOURCE: Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Posted on Dec 09, 2008
Anonymous
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: can not reset clock or timer, oven will not work
Try pressing the first 2 buttons on the left, and the last button on the right of the timer all at the same time.
It may differ to this depending on the actual model, but it is usually a combination of 2 or 3 buttons.
Hope this helps, if it does solve the prob, please feedback.
Thankyou.
Posted on Dec 21, 2009
MY WHIRLPOOL OVEN KEEPS RESETTING A PROGRAMME BY ITSELF EVEN IN MID COOKING. THE OVEN IS ONLY 18 MONTHS OLD. WHIRLPOOL WONT HELP ONLY AT A COST.
Although the manufacturer only give a 12 month guarantee it is down to the retailer to sort faults. Under statutory rights you have up to 5 years to male a complaint. Get a quote for repairs and issue a claim in the small claims court.
Sep 30, 2014 | Whirlpool Ovens
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
The time blinks at 12:00, there is a beeping sound, the oven does not work. It's only 2 years old.
Hi.
The beeping sound is a warning because the oven is in lock condition, or because a fault had been detected. In this last case there would be an error code or something unusual.
Push and hold the Clock button for about 10 seconds, that will reset the oven. If that does not work, then trip the circuit breaker for five minutes and hold the button again to reset.
If still no luck, then there may be a fault condition. In that case better calling the Frigidare number listed on the owners manual.
If the oven is two year old , then there may still be warranty cover on parts, one more reason to contact the manufacturer if the oven does not reset.
Try resetting the oven first.
Regards.
Mar 04, 2010 | Frigidaire FGB24S5A Gas Single Oven
Inner glass shattered while on broil temperature. How does this happen? I will call service, but my over is about 8 months old. This is very dissapointing
It is really just coincedence if you hadnt bout it then somone else would have and they would feel like you feel now. It was probably a small crack or defect just outside eye view in your oven door or just a bad piece of glass that wasnt hardened just right. There isnt a large volume of these happening on your model# and I wouldnt worry about it. Stuff just happens, plus this opens a door for you most buyers wont have. If something else happens in say 3 years the control board shorts out. You then call Whirlpool and tell them they should have replaced the unit from the start cause you think its a lemon. Since you had issues with it in the first year, they will usually cover any repair and parts cost for you even though most appliances only have a one year warranty on them. Lastly, no this was not a cheap purchase and yes it does stink that it broke but at least it did happen while in warranty. Just tryin to help you make lemonade with your lemons. Hope I helped.
Jan 25, 2010 | KitchenAid Architect Series KEMC308KSS...
Is there a reset switch for Decor Electric oven? Kids turned on self clean and read out stopped working. Unit is at least 10 years old.
You can reset the oven by shutting down the breaker for the unit for an hour or 2, if your oven is over ten years old it might not help, the board could have been fried, good luck
Jul 15, 2009 | Dacor Ovens
No heat
Hi.
If your oven is less than a year old, then you should contact the store where you purchased it from or contact the manufacturers service department , as it should still be under guarantee.
Hope you get your problem solved.
Cheers
Nov 27, 2008 | Ovens
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
2,145 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
