Zebra Eltron TLP 2844 Thermal Label Printer Logo
A
Anonymous Posted on Sep 17, 2013
Error 0x0000007a - Zebra Eltron TLP 2844 Thermal Label Printer
Error code 0x0000007a
This error code is usually an issue with the print spooler service of the Windows OS on your PC. I would advise running the Microsoft Fixit tool
Print error 0x0000007a
reset your print spooler
Start -> Services -> (scroll down to print spooler) -> Stop, then restart.
1helpful
My desktop is getting stuck so many times. It shows bluescreen and physical memory dump even when i tried to install new copy of windows. the error is technical error stop : 0X0000007A(0XCO7B9FB8,...
It can be a few things but usually the atapi.sys file is corrupt. If you can boot into your desktop, open the "run" box and type in "cmd". In that box type: sfc /scannow and press enter. There is a space between sfc and /scannow. You will be asked to put your Windows CD in the CD drive.
When did this problem begin? Have you installed a new harddrive recently? Have you installed new memory recently? Remove and re-insert the hardrive cables. Remove and re-insert the memory. Be careful about electro-static discharge. Sometimes just doing that will fix a bad connection.
Sometimes this error is caused by bad memory. You can download Memtest86 here: http://www.memtest.org/ Grab the prebuilt ISO.zip After downloading the file right click it and select "extract all" Use Img Burn http://www.imgburn.com/index.php?act=download to write the ISO to a CD. Keep the CD in the drive and reboot.
Also, there could be a problem with the hardrive. if you know the harddrive manufacturer you can usually go to their website and download their hardrive diagnostic software.
Sometimes erasing the hardrive (absolute last resort) will solve these kind of errors. Just be aware that you will lose ALL of your data and it mat not solve the problem. Darik's Boot and Nuke works good for that: http://www.dban.org/
Dear Sir ,i have a hp officejet j3608.igetting amessage saying error 0x0000007a- test page failed to print .Thankyou Brian Tilgner.
Hi
Please clean all your %TEMP% files and run as administrator
and use the below software to clean your problem
www.reggenie.com
Thank you
Harsha
Error 0X0000007A keeps rebooting
If you have a windows installation software, insert it in your diskdrive and choose repair.
4helpful
2answers
Error message 0x0000007a
Google HP error message 0x0000007a and see what feeds back. I get the best answers that way
Bsod during windows installation
Try doing this as suugested, you might not need reformatting.
http://www.pcreview.co.uk/forums/thread-94921.php
2answers
Printer just wont print anything! when i tried to print a test page it came up with an error code 0x0000007a?
Then it's a F**k **** old thingy!!!
go buy a new one!!
i promise it's worth it than sacrificing for that old one!!!
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
