Hello here is the mainboards homepage:
http://www.msi.com/product/mb/G31M3-F.html#/?div=Driver&os=All
The manual:
http://www.msi.com/product/mb/G31M3-F.html#/?div=Manual
No display is often caused by a wrong ram module.
I mean the mhz is wrong.
Your mainboard uses DDR2 667/800 if a higher mhz ram is inserted this can cause no display.
If the cpu fan is running, its the ram module that causes this issue.
But of course it could also be the power supply, or a bad graphic card.
Try to boot up with only one module, and make sure the module is correctly inserted in the slot.
Good luck
SOURCE: Driver Motherboard Msi Ms 7528 Ver 1.1
Drivers for the MSI G31M3-F (MS-7528) can be downloaded here.
If this helps to solve your problem then please take a moment to rate this post - thanks.
SOURCE: MSI MS-7507
That board is known to MSI as 945GCM7-L, and you can download the drivers HERE.
Thanks Mark
SOURCE: My motherboard is(msi ms-7528)Ineed sound driver
Pls. Give me a my MSI K8MM-V MS1996 Motherboard Audio Driver
SOURCE: lost mother board CD sound drivers not installed
Hello download here:
http://www.msi.com/product/mb/KM4M-L.html#/?div=Driver&os=All
Here is the other model:
http://www.msi.com/product/mb/KM4AM-L.html#/?div=Driver&os=All
Please select driver and your windows system.
Any file from here needs to be unziped before you install.
Not all windows system is supportet.
Good luck
