I have a samsung sgh d807. When I turn on my phone it prompts for a password and I dont know what it is, someone changed it on me and cant remember it. Is there a master password or a way to reset the phone, If anyone can help me out I would really appreciate it thank you
i forgot my password and i try all the codes that rogers and samsung give me but that did not work so i need help. they told me that the only way that they can unlock the phone is that they do a reset flash but that will delete everythang on the phone can any one help plase.i forgot my password and i try all the codes that rogers and samsung give me but that did not work so i need help. they told me that the only way that they can unlock the phone is that they do a reset flash but that will delete everythang on the phone can any one help plase.
You can't post conmments that contain an email address.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey. (just keep pushing the down key to get a menu)
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
I found this off another site. I have tested this withy my D807 and it works. 1. If you have changed your phone password, change your password back to the default 8 zeros (00000000). 1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding. 2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin) 3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#. 4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu) 5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear. 6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear. 7. Turn off your phone and put the original SIM back in. 8. Turn on your phone. You will receive a prompt to enter a password. 9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on) 10. Completed. You have now unlocked your phone.
Easy as pie. Now you have an UNLOCKED Samsung D807 =) worked on my brand new 2 day old Samsung D807 phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000). 1a. NOTE: Go to SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding. 2. Put a SIM card that is from a network other than the one your phone is locked to 3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#. 4. White screen will appear with an exit option. Press the right softkey. (you may have to push the down key to get a menu) 5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear. 6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear. 7. Turn off your phone and put the original SIM back in. 8. Turn on your phone. You will receive a prompt to enter a password. 9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on) 10. Completed. You have now unlocked your phone.
this may be what you allready tried, but it worked for me, good luck
D807 Unlock Samsung SGH-D807 SOLUTION for those that need this code. It's a lot cheaper than 29.00 from some of these websites....
-------------------------------------------------------------------------------- 1. If you have changed your phone password, change your password back to the default 8 zeros (00000000). 1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding. 2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin) 3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#. 4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu) 5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear. 6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear. 7. Turn off your phone and put the original SIM back in. 8. Turn on your phone. You will receive a prompt to enter a password. 9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on) 10. Completed. You have now unlocked your phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone only you will need a data cable..
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
If you have changed your phone password, change your password back to the default 8 zeros (00000000). NOTE (Modification here by my experience): Go to SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
Put a SIM card that is from a network other than the one your phone is locked to.
When Incorrect SIM error comes up, input *#9998*3323#.
You now have an UNLOCKED Samsung D807
With the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card.
the default code is the last 4 digits of your phone number unless you have changed it. In that case maybe a retailer could flash your phone back to the default settings.
