Computers & Internet Logo
Darlene Brabant Posted on Sep 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Could not initialize BDE.: network initialization failed
midland10
Level 2:
Scholar:
  • Expert 110 Answers
  • Posted on Sep 23, 2013
midland10
Expert
Level 2:
Scholar:
Answers
110
Questions
Helped
27805
Points
238
You need to go to the BDE Administrator (control panel) and change the location of the network control file (the net file).. most modern windows installations won't let you write to the root of a drive.. and when you install on a network, do the same thing, but point to someplace every machine can get to.. in that case, the net file folder and all shared data MUST be exactly the same from every machine..
How do I initialise hdd on hikvision 7216 when msg says initialisation of new hdd failed
You need to Format first before initialize HDD. when format done you can initialize the HDD. Check the Format Option in Storage Management.
For more Help You can visit my YouTube Channel:-
CCTV Networking Technical Support
tip
Unlock Your Nokia mobile phone with Code Calculator
What is Unlocking?
Unlocking a mobile phone is the procss of removing any SIM Card or Network restrictions set on the phone by either the manufacturer of the phone or by the mobile phone's service provider. After unlocking a mobile phone, you can still use it with it's existing network or switch over to any other supported network.
Get free unlocking codes here
1helpful
Yahoo messenger.exe- application error. the application failed to initialize properly
why is it my yahoo messenger that id download now is failed to initialize properly? can you please help me the right thing to do to make my download completed?
3helpful
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Initialization failed
You need to uninstall and Reinstall the particular game.. or try system restore for quick resolution
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Network will not initialize
you need to shut the machine down, turn off power and restart it... it should go through the Network Initializing after it has connection with the network, this screen should go away..
Grand Canyon Tech
Grand Canyon Tech
