Treadmill console will come on for about 15 seconds. If I don't hurry up and press the password and start it will shut off and won't come back on. I have to wait for about 30 mins to try it again. If I do get the password in and start it ill be fine for about 4 mins and then shuts off. The switch is flipped the I can't turn it back on with the display working. The motor fan is running. There is a solid red led light on but goes off when the display goes off. Help!
You must replace the control board electronic.
Go to www.treadmilldoctor.com
and get it see the diagram how the control board control almost the 80% of the machine.
God bless you
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
SOURCE: Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
SOURCE: Fuel FT94 Treadmill troubleshooting
It stops and when I unplug it it starts again this happens 4 or 5 times what is wrong?
[email protected]
SOURCE: I have a PROFORM J6
This is not a fuse problem. If it was a fuse then it would not work after it quit. It is the motor that is going out. The motor has a thermal overload. This is what is making the motor shut down. But it is not always the motor that is going bad. Sometimes you can oil the bearings and this will fix the motor from overheating. By the bearings I mean the ones in the front and rear roller of the treadmill.
SOURCE: I have a Lifefitness Treadmill model TR 9100,
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
1 )Locate
the reset switch on the underside of the treadmill console. Usually
the button is large enough to trigger with a pencil eraser or Q-tip.
Plug the treadmill plug back into the wall. Use the Q-tip to press
the reset button. It may be necessary to hold the reset button down
for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
