Tools & Hardware - Others Logo
Paul Posted on Sep 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find a plan for a tool stand, specifically a palm router station?
seraphina
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Sep 17, 2013
seraphina
Expert
Level 2:
New Friend:
Answers
43
Questions
37
Helped
24575
Points
132
1helpful
Where can i buy a docking station for my archos 43vision
Here is variety of docking station and universal mouting for your Andriod Palm tablet PC Notebook, http://www1.shopping.com/docking-station-Archos-28-Internet-Tablet-4GB-Android-Palm-sized-Tablet/products?CLT=SCH#
My first problem: I have a Verizon Samsung Alias 2, which is having problems. Solution to first problem: I bought a new non-contract Verizon Palm Pixi Plus to replace the Alias 2. Second problem:...
No, you cannot unlock the Palm Pixi Plus and put it on a plan that is not compatible with a smartphone. If you want to continue to use Verizon service, you will have to purchase a phone that is compatible with your current plan, or change to a different plan that will work with your Pixi Plus.
6helpful
Can i unlock a sprint palm pre to be used on an at&t service plan
absolutely not. SPrint is a CDMA network, meaning the device must be manufactured specifically for that network. CDMA networks use HEXidecimal codes to connect to the network. This is the same type of service used by cricket, verizon, and many other providers that use CDMA devices. Your Palm can be "flashed" with the proper setting to work on any of these networks, but as long as the network requires a sim card it will not. Sim cards are used on GSM networks, which run on a totally different frequency lvl.
THe only way to make the device work is to be a phone genius and "hack" a sim port onto the board. Unfortunately, this is so complicated, i have only been able to it to one device (a first generation palm centro) and the device experienced many problems and after a few months, shorted out completely.
SO DONT TRY!!!! your best bet is to find someone that will trade you straigh out.
GOOD LUCK AND PLS RATE THIS POST!!!!!
Can connect to router, but not to internet
Is the main computer connected to the router or to the internet directly? If it is a cable modem for the internet, make sure you turn that off, as well as the router, and connect the cable modem to WAN on the router and put the modem on first, then the router. Connect the computers, xbox, etc to the router
Microsoft mn 100 router will not connect nor will it allow me to go into management tool. It worked up until today, I use it to run xbox 360 online. I kept getting alert about my nat was at moderate and...
You might try re-setting MN-100 router back to the default setting. Do this by ... look in the back, there is a small hole at one of the ends. I have mine standing up and the (small) hole is at the top. Which you can use a straighten out paper clip and lightly push it in the hole to re-set. The trick to it - is that you have to hold it for a little bit of time. I'm not sure what the time figure is, 5 or 10 seconds something like that ... but the lights on the front will start to blink. Look in you manual, it will show you where the hole is.
1helpful
3answers
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
WiFi not connecting to cisco router
most likely the Palm "listens" on another frequency.
Make sure your cisco is running the Wireless b standard as that is what the Palm Tx needs.
Mixed mode is another option (b and G at the same time)
Let's say your router is supporting the b standard. Knowing the cisco APs a bit, it is also possible to have a channel selected that an older device cannot see/or it is set for another region (which in fact is the same, as frequency ranges are different for each continent).
There are many tools for WIFI analysis, many are free. They will tell you what your router is transmitting at, etc... withouth having to go into the cisco IOS.
2answers
Reconnecting Wired Base Station MN-100
Yes, that is possible. Since you have changed providers, you have to reconfigure the router depending on your new provider.
You can try these steps:
1. Turn off the the router, modem and the computer.
2. Wait for 30 seconds then turn on the modem and make sure that all (if not most) lights are stabilize
3. When the lights are stabilized, turn on the router and wait for the lights to stabilize.
4. When both the router and the modem are stabilized, you can turn on the computer and check for the connection.
If it still does not work, you may need to configure the router based on the settings needed by the service provider that you have. If you wish, inform me of the name of your service provider and I will give you the specific settings on how to configure your router.
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
