Question about Stanley Camping, Backpacking & Hiking
SOURCE: My LG Chocolate won't charge
seems like the battery is dead. just get a new battery
Posted on Nov 11, 2008
SOURCE: Eee PC does not turn on!!
there could be a variety of problems....first off try a simple power cycle..remove the battery and keep poewr adapter in...then push power button down for 1 minute...then push the power button normally and might correct problem....if not check the brick the power adapter box for lights or warmth...if not warm it could be bad power adapter....if it has warmth and lights then it could be the battery...if you have a warranty on hte computer now would be a good time to call the warranty companie...but try those steps first...they are simple troubleshooting steps...
Posted on Apr 16, 2009
SOURCE: 1991 Dodge Dynasty LE
Sounds like you are having a fuel problem with the fuel filter. If you have not had your car serviced in quite awhile i would do so. At least change the fuel filter and check the air filter as well. Hope thias will help you.
Posted on May 28, 2010
SOURCE: Was using my Hp Pavilion dv7 laptop, suddenly
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Oct 10, 2010
SOURCE: I have a 1984 dodge D150, not charging, battery is
The first thing you need to do is stop wasting your money by replacing parts. Then get a volt-ohm meter and a test light to test the circuits between the battery, the alternator, the ignition switch, the starter relay and the voltage regulator. (a.k.a. Charging System Circuits)
To start, the "B+" or "BATT" terminal on the alternator (large black wire) MUST have a solid, direct connection to the battery. Check for the proper voltage here. Then, the red wire on the alternator at the "F2" terminal should be HOT at all times. If not, you probably still have a bad fuse link that you missed. The "F1" terminal on the alternator (Light Green wire) is known as your "FIELD" wire. It comes from the "IG" terminal at the voltage regulator. It should be hot any time the key is in the ON position. If not, your voltage regulator is not working or your ignition switch is not providing power to the regulator. Finally, The "F" terminal (Red wire) at the regulator should be hot any time the ignition switch is in the ON position. This actually gets it's power from the starter relay, which gets its power from the ignition switch.
Please also review these articles:
What Else Could Be Wrong?
My Car Won't Turn Over
Posted on Jun 12, 2011
Oct 04, 2017 | Volvo Cars & Trucks
Jan 01, 2015 | Amazon Kindle 3G
Mar 03, 2011 | Black & Decker Drills
Oct 31, 2009 | 2002 Chevrolet Monte Carlo
Aug 25, 2009 | GE Heating & Cooling
Jun 22, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Jun 21, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Apr 20, 2009 | Garden
78 people viewed this question
