Televison & Video Logo
Phillip Healey Posted on Sep 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Television KV-29-SN21
Hi My sony TT just sits cycleing, tring to start up. It has not blown the fuse, and I can see a small flash in the gun are of the CRT.
  • Phillip Healey
    Phillip Healey Sep 19, 2007
    I have done electronics at RMIT, graduating as in Industrial Electronics in 1975. I mainly do work in Valves, but having been involved in communication electronics do not get into to CTV's all that often. I have an understanding of the perils of high voltage and the methods to protect and work safely.
    Given this, any pointers you can provide on this situation I would be able to investigate.
    Looking forward to your views,
    Many thanks
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 556 Answers
  • Posted on Sep 16, 2007
Anonymous
Expert
Level 2:
Prodigy:
Answers
556
Questions
0
Helped
171577
Points
916
Caution small flash in the gun of the CRT. please DO NOT PUT ON TV again. call skilled tech. to see high output in power supply.
  • Anonymous Sep 19, 2007
    flash near gun is not a good sign for crt.
    please check crt electrodes for high voltage.
    if power supply is giving high voltagr this type of situation arises.
    & finally check for crt.
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
1helpful
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
4helpful
Sony tv kv-xj29m80 need to know what error code 2 means
IN THIS SONY TV KV- XJ29M80, IM FACING A PROBLEM THAT SET GOES TO ERROR MODE WITHIN FEW SEC'S AFTER GETTING IT ON, AND THE LED INDICATES 2 BLINKS AND GAP AND AGAIN 2 BLINKS AND CONTINUES..PLZ HELP ME ...I WAS FOUND THE HORIZONTAL OUTPUT TRANSISTOR BLOWN AND THE 1.2 OHM RESISTANCE ALSO FOUND BLOWN...I REPLACED THE BOTH BUT THE PROBLEM IS CONTINUE...
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
4helpful
Sony Trinitron
HI!
Observed the standby light for flashing;becaused there is diagnostic code for flashing;
If ever there is no sign of standby light,your power supply is depected maybe a blown fuse,if you know how to open the back cover,you can replace that fuse,it is very easy (DIY) do-it- yourself.
I will follow the diagnostic code;
Hopes it may help you;
Regards,
VOTIT
Sony KV-29-SN21 TV power supply clicks, no picture no sound
DO NOT PUT ON TV As it is DANGEROUS call tv tech to check high output in regulated power supply
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Top Televison & Video Experts
 Grubhead
Grubhead
Marvin
Marvin
