Question about Rheem Heating & Cooling
Outside fan not coming on - Rheem Heating & Cooling
Inside unit comes on, outside unit buzz's fan does not come on. ac has stoped cooling
TRY TO PUSH OUTSIDE FAN WITH A SMALL STICK IF FAN IS TIRNING ALRADT THE CONTACTOR IS GOING OUT.FAN NOT TURNING STARTUP COMPASITOR IS GOING OUT
Aug 11, 2011 | Gibson Heating & Cooling
My Goodman gsh103301ab. The fan in the outside unit will not come on. The heat is still coming out the the vents but, just don't think that sounds right. Is this suppose to happen?
If it's in cool mode, the outside fan definitely should run to remove the heat. If it's heat mode the outside fan will start only when pressure build up. If it's problem with condenser fan definitely the breaker or fuse will be blown when the amphs increased.
Dec 08, 2010 | Goodman CKL36AR36 Air Conditioner
Is it normal for fan on outside unit to be on while on heat mode
Yes, it is normal with a heatpump, you run the outside unit in cooling and heating.
It is also normal when the outside unit goes into defrost for the outdoor fan to shut off during the defrost mode and to see steam coming out of the outside unit, while it's melting the frost or ice, then the fan will come back on.
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
When is the fan outside suppose to stop? mine stops all of a sudden and doesnt come back on for hours ...why?
In general the fan outside should match the blower inside of when it is on or off(give or take a minute or so).
If your fan outside is stopping while your blower inside is still going, then the fan motor(outside) might be going out.
Aug 20, 2009 | Heating & Cooling
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
243 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
