SOURCE: Mercedes-Benz Transmission Fluid question
the transmission on your MB is sealed with no way to check the trans fluid level,(no dipstick provided for) that is why the report says "sealed". MB did this to stop customers from overfilling there transmissions, which can cause severe damage if not done properly at the correct fluid temp, this requires special test scan tools.
SOURCE: can't open a 2002 Mercedes c230 kompressor sun roof
It's typically the motors or the special drive tubes that it uses. If you here a clicking noise then the sunroof became to tight and ruined the motor gears. You can actually switch the two motors, one is for the shades and needs less power then the other motor. They are identical, switch them. Nex make sure they are very tight to the 3 mounting bolts, there is a rubber washer bushing that wears out and alloys the motor to flex too much, causing the gear mis-alignment and gear grinding. This works great I do it all the time.
SOURCE: what do i need to service my car mercedes benz
i have a Mercedes Benz C200 Kompressor , I just changed the plugs, air filter and oil filter and put new oil, but it's now miss firing badly can some one out there help?
