Question about Sanyo DS27510 27" TV
Sanyo ht27547 do I need a converter box or just an antenna?
6ya staff
SOURCE:
Anonymous
SOURCE: Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Posted on Feb 29, 2008
Anonymous
  • 20 Answers
SOURCE: Sanyo HT27547 tv - lightening came in on coax line
Ther is probably a fuse and a diode that got hit by the lighting. If you want to try to fix it yourself unplug it check the fuse and change it if it is bad. Then turn it on again. If it blows that fuse then a diode is also out.
Posted on Mar 19, 2008
Bob Citizen
  • 520 Answers
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Posted on Jun 28, 2008
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Posted on Dec 01, 2008
Anonymous
  • 83 Answers
SOURCE: Is my Sanyo DS20930 digital ready or will it need a converter box
if it was bought prior to 2005 it may not be, if it has freeview/freesat in it then it will be digital ready or if you have sky/virgin then you will be ok
Posted on Jan 24, 2009
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Dec 26, 2008 | Sanyo HT27546 TV
Nov 21, 2008 | Sanyo DS31590 31" TV
DTV Compatible
If you do not have cable or satellite then you will need a converter box for Antenna only those who will be using antenna for signal will need box.
Oct 30, 2008 | Sanyo DS20930 20" TV
Digtal Signal Ready?
If you wish to continue to use the antenna, you will need a converter. If you only use cable, no converter is required.
Dan
Jul 30, 2008 | Sanyo DS31590 31" TV
Re: Sanyo TV Model #: HT27547 Will I have to get a converter box to watch tv stations?? In a few days I will disconnect my satellite service. Thank you!
This link will verify that yours is digital ready.
If not click able go here.
http://reviews.walmart.com/1336/5652233/reviews.htm
to see reviews for your Sanyo flat screen model ht27547
You may have to purchase a new antenna to do that search for one that is specifically for digital reception and good for the distance from station to home. (Range rating)
Apr 25, 2008 | Televison & Video
Mar 18, 2008 | Sanyo HT27546 TV
Sanyo DS27510 27" TV Logo
67 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
